problems with @during with hourly frequency
francisco
Postby francisco » Fri May 22, 2020 10:20 am
When I want to create an indicative variable with @during("04/04/2020 01:00 04/06/2020 01:00") (for example) in Eviews11, it doesn't work.
Could you please help me?
Francisco
EViews Matt
Re: problems with @during with hourly frequency
Postby EViews Matt » Fri May 22, 2020 2:14 pm
It appears that @during doesn't accept intraday date notation. For the time being, you can work around this by using an @after and @before clause instead, e.g.
series ind = @after("04/04/2020 01:00") and @before("04/06/2020 02:00")
francisco
Postby francisco » Fri May 22, 2020 2:31 pm
ok. Do you have plans that in the future @during will also work with data in time frequency? ... with time data I have also tried to estimate models with breakls (Least Squares with Break Points) but it does not work ... it is also due to the @during command What doesn't work? ... What can I do to estimate a breakls model with data in hourly frequency?
EViews Matt
Postby EViews Matt » Fri May 22, 2020 4:12 pm
There does seem to be an issue with BREAKLS in an intraday workfile. It doesn't appear to be related to @during, but I'm still investigating. I don't have a workaround for you, other than perhaps to use an undated workfile for the time being.
francisco
Postby francisco » Fri May 22, 2020 4:23 pm
Okay. Thank you.
Postby EViews Glenn » Sun May 24, 2020 7:04 am
We will look into this.
[Edit: in the process of testing a fix.]
Postby EViews Glenn » Tue Jun 09, 2020 3:15 pm
A fix has been posted.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
