GMM and covariance among factors
RDS
Postby RDS » Thu Jun 06, 2019 2:48 pm
Given the 7 variables (y1,...,y7) and the tree factors (x1, x2 and x3), is it possible to save the covariance of factors x1, x2 and x3 using GMM, after solving the system below?
system SDF
SDF.append ( y1*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y2*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y3*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y4*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y5*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y6*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF.append ( y7*(1 - c(1)*(x1 - c(4)) - c(2)*(x2 - c(5)) - c(3)*(x3 - c(6))) ) = 0 @ c
SDF_all_{%type}.append ( X1 - c(4) ) = 0 @ c
SDF_all_{%type}.append ( x2 - c(5) ) = 0 @ c
SDF_all_{%type}.append ( x3 - c(6) ) = 0 @ c
param c(1) 0.9 c(2) 0.9 c(3) 0.9 c(4) 0.9 c(5) 0.9 c(6) 0.9
'Sequential weighting matrix & coefficient iteration
'Cross section (White Cov) will result in GMM estimates robust to heteroskedasticity of unknown form
SDF_all_{%type}.gmm(instwgt=white,method=nstep,wtype=istdev,s)
RDS
Re: GMM and covariance among factors
Postby RDS » Thu Jun 20, 2019 7:23 am
I am able to save the coefficients of this system in a Table, for example
Table(1,1) = SDF.c(1)
but I am not able to save the standard errors
do you have a suggestion?
RDS
Postby RDS » Thu Jun 20, 2019 7:45 am
problem solved
Table = SDF.@stderrs(1)
RDS
Postby RDS » Thu Jun 20, 2019 7:52 am
No, actually not, because @stderrs(1) refers to the 1st coefficient, which is not necessarily c(1)
How can I get the standard errors, which are associated directly to the parameter c(1): something like @stderrs(c(1))?.
Postby EViews Gareth » Thu Jun 20, 2019 8:15 am
No, you'll have to work out the translation manually.
Users browsing this forum: No registered users and 5 guests
