How do i turn off date the date axis grid lines in a program? I'm able to go into the chart options --> axis & scaling --> grid lines --> Obs & Date axis grid lines and i can choose none. This works, but chart_1.axis(b) -grid seems to have no effect
thanks
Re: Date axis grid lines
The 'axis' proc refers to axis containing data. I am assuming your bottom axis is the time axis in which case you need to use the 'options' proc.
If this is true, try
but turning off all grids will also turn on the frame. So you will also have to specify the frame border setting. For example, use
chart_1.options gridnone
chart_1.options gridnone frameaxes(none)
