How to get p values alongside VAR/VECM results in same window
vaibhavapj
Postby vaibhavapj » Fri May 03, 2019 12:06 am
When we apply VAR/VECM we only get the coefficient value and standard error. Then we to have separately run a process to get the p values also. How can i get all these in one process to save time and get better output
Also, is it possible that if we have say 1 variable crude and we have to run seperate VAR/VECM with 5-6 different variables like
oil &sensex
oil & nifty
oil &dollar,
oil & gold
we can do that in just 1 command or code?
Re: How to get p values alongside VAR/VECM results in same window
Postby EViews Gareth » Fri May 03, 2019 6:45 am
You will need to create a program for both your questions. There is nothing built in that will do it.
vaibhavapj
Postby vaibhavapj » Fri May 03, 2019 10:36 pm
Thanks.
But i feel atleast the first issue must be there in the software by default. This is very important and used widely.
Users browsing this forum: No registered users and 17 guests
