smpl if in loop
Frdmn
smpl if in loop
Postby Frdmn » Mon Apr 08, 2019 8:08 am
I'm trying to create pages based on cross sectional attributes (my cross-sections are countries and I want to create a new page and sample if countries are in a specific region, like Asia of Latin America.
The code is the following:
%sub_region = @wjoin(@uniquevals(sub_region_code))
for %i {%sub_region}
pageselect Baseline
pagecopy(page={%i},nolinks)
smpl if sub_region_code=%i
But Eviews outputs the following error (SUBAFR is my first sub_region, in all caps):
Error in Sample:  SUBAFR is not defined in "SMPL IF
 SUB_REGION_CODE=SUBAFR".
Is anyone having the same issues? this is EViews 10.
Thanks!
Re: smpl if in loop
Postby EViews Gareth » Mon Apr 08, 2019 8:23 am
There's nothing inherently wrong - this seems to work:
'create a panel with some cross-sections identified by sub_region_code
wfcreate(page=Baseline) a 1990 2000 15
alpha sub_region_code = "sub_" + @str(@crossid)
pagestruct() sub_region_code @date(dateid)
   pageselect Baseline
Frdmn
Re: smpl if in loop
Postby Frdmn » Mon Apr 08, 2019 8:35 am
Thanks for your quick response Gareth, but this doesn't work on my version of EViews,it throws the following error:
Error in Sample: SUB_1 is not defined in "SMPL IF
SUB_REGION_CODE=SUB_1".
Any clue? maybe case sensitivity? Maybe trying EViews 11?
Re: smpl if in loop
Postby EViews Gareth » Mon Apr 08, 2019 8:55 am
What's the build date on your copy of 10? (Help->About EViews)
Frdmn
Re: smpl if in loop
Postby Frdmn » Mon Apr 08, 2019 9:02 am
it says Mar 22 2019 build, I'm not administrator*
I installed EViews 11 and your code works on this version.
Re: smpl if in loop
Postby EViews Gareth » Mon Apr 08, 2019 9:07 am
When you run the program in 10, make sure the "version 4 compatible mode" is unchecked.
Frdmn
Re: smpl if in loop
Postby Frdmn » Mon Apr 08, 2019 10:35 am
Amazing Gareth, you're the man!
