error when seasonally adjusting multiple series
pcruzd
Postby pcruzd » Fri Mar 08, 2019 8:47 am
I am having trouble when seasonally adjusting (x13) multiple series. I am getting an error that appear only certain times and I have to run the exactly same code 5 to 6 times until the error magically doesn't appear. The error that I am getting is: 'Unable to open file c:\users\username\appdata\ev_temp\evx13tmp.spc in "SER{!X}.X13("SAVE="D11 D10")". Please help
PS. I'm using Eviews 9.5
Re: error when seasonally adjusting multiple series
Postby EViews Gareth » Fri Mar 08, 2019 9:02 am
That error indicates that something went wrong inside the X-13 executable. Unfortunately we don't have any control over what goes on inside it, so there isn't much we can say.
pcruzd
Postby pcruzd » Thu Mar 21, 2019 7:03 am
Thanks Gareth,
So far I've been able to manage it using setmaxerror and @errorcount, but Im having a problem when additional errors appear (like no seasonallity in the series). So I would like to know if there's any way to know what type of error im getting while running the program. For instance, to generate a lable with the text that appears in the log file when an error occurs.
Actually, my code is
!err = 0
for !x = 1 to 50
   !newerr = !err + @errorcount
   if !newerr>!err then
      !err = !newerr
      !count = 0
      !maxcount = 20
      while !count <= !maxcount
         if !newerr=!err then
            exitloop
         endif
         !count = !count+1
      wend
   endif
pcruzd
Postby pcruzd » Thu Mar 21, 2019 7:29 am
I just realized I posted an old code with errors, here is the actual one:
for !x = 1 to 50
   !err = @errorcount
     !check= @errorcount-!err
      if !check>0 then
         !count = 0
      !maxcount = 20
            !err = @errorcount
            if !check=0 then
               exitloop
            endif
            !count = !count+1
         wend
      endif
Users browsing this forum: No registered users and 11 guests
