Cointegration Test gives wrong P-Value
grabodan
Postby grabodan » Tue May 15, 2018 5:53 am
Dear EViews-Team
When I perform a Johansen Cointegration Test for a VAR and the Trace od ME Test Statistic are much larger than the critical value, the p-value should be close to zero. Instead, I shows the Prob: 1.0000.
The programm code I used, just as an example, was:
wfcreate(wf=Koint) u 10000
smpl @all
series x=0
series y=0
series z=0
series trend = 0
smpl @first+1 @last
series u=@nrnd
series v=@nrnd
series w=@nrnd
trend = 1+trend(-1)+@nrnd
x= trend + u
y= y(-1) + 0.5*(x(-1) - y(-1))  + v
z= 10 + z(-1) + w
varest 1 1 x y z
I am using EViews 10, but I think I have encountered the same problem already years ago with Version 8 or so.
Edit: The issue disappears if, e.g., I reduce the number of obs to 1000 such that the p-value is 0.0001 or such. Thus, I only appears for p-values extreme close to zero, displaying 1 instead.
Best regards,
Daniel
koint.wf1
(665.94 KiB) Downloaded 68 times
Re: Cointegration Test gives wrong P-Value
Postby EViews Glenn » Tue May 15, 2018 9:37 am
Thanks. We will take a look.
Postby EViews Glenn » Fri May 25, 2018 4:47 pm
We've identified the issue.
In the MacKinnon algorithm for the response surface, we have found that there are potential issues with the polynomial approximation to the response surface for extreme values. In this case, the statistic value is so out of bounds that the existing algorithm approximation is quite poor. We have implemented a fix for the tail conditions which provides additional robustness to these large values and are in the process of testing the changes. A fix will appear soon (most likely in the next patch for EViews 10).
Thank you for your patience.
grabodan
Postby grabodan » Mon Jun 04, 2018 6:31 am
Thanks for the response,
Daniel
