Is there any possibility to estimate a panel VAR in eviews 9?
Kind regards
Panel VAR EViews 9
Re: Panel VAR EViews 9
Which estimation technique did you have in mind?
Hi Gareth am trying to estimate a Panel VAR using Eviews 10. Is this possible?
I would to estimate a PANEL VAR with either FIXED EFFECTS, RANDOM EFFECTS or USING the GMM. In other words whichever is appropriate.
Regards
Regards
EViews Gareth wrote:Which estimation technique did you have in mind?
None of those are built in, unfortunately.
You could estimate a standard VAR and use @expand(@Crossid) as an exogenous variable which might give you the fixed effects you want.
Thanks Gareth, I have tried it and it has worked. How do include random effects ? or Is there a way of estimating using the GMM?
Is it possible do do some of this by manually writing out the VAR as a standard regression?
Hi Gareth,
Is it possible to get impulse response functions for Panel VAR if use the @expand(crossid) command in the exogenous section of the VAR window.
Reagds
Reagds
- data.xlsx
- (15.41 KiB) Downloaded 71 times
Dear Gareth,
Reagd
Reagd
Impulse responses work in exactly the same way as a non-panel VAR.
Users browsing this forum: No registered users and 9 guests
