Diebold-Yilmaz index
dakila
Re: Diebold-Yilmaz index
Postby dakila » Tue May 14, 2019 4:40 pm
What is your eviews version?
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 9:09 pm
Eviews 11.
dakila
Postby dakila » Tue May 14, 2019 11:30 pm
Yes, you are right. It does not work for the version 11. I will fix it soon. But it can work for the version 10 if you have access to it.
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 11:59 pm
I have also Ev 10+ and the same error appears.
dakila
Postby dakila » Thu May 16, 2019 6:15 pm
The bug is fixed. Please update the add-in. I hope the moderator will post it soon. But carefully choose the rolling window parameter. It should not exceed the sample size.
Wiz_Ven
Postby Wiz_Ven » Fri May 17, 2019 5:31 am
Thank you very much. As soon as the new version of the code is online I will try to run the code following your instructions.
Wiz_Ven
Postby Wiz_Ven » Fri May 17, 2019 10:03 am
Dear Dakila,
I have tried the updated version. Now it works fine. Thank you very much.
Asimshaikh
Postby Asimshaikh » Thu Jun 13, 2019 12:20 am
dakila wrote:This thread is about the dyindex add-in that estimates the Diebold-Yilmaz index of spillover using forecast error variance decomposition method of a VAR model.
I am new to this method can anybody help me by telling steps to calculate dyindex?
Asimshaikh
Postby Asimshaikh » Sat Jun 22, 2019 1:10 am
Helloe everybody
I have calculated spillover index using this add-ins but one thing i am still unable to get is net pairwise connectedness.Can anybody help on this?
dakila
Postby dakila » Sat Jun 22, 2019 1:21 am
When estimate the DY index just tick the save pairwise spillovers. After that do it manually get the net pairwise connectedness.
harpreet_kaur
Postby harpreet_kaur » Sat Jul 20, 2019 1:36 am
Hi, i have applied Diebold model in Eview9 to check return spillover among five return series ( daily data, around 3000 observation). I have some queries
1. Endogenous variable should be stationary?
2. On the basis of lag length criteria, appropriate lag is 1 (SC) and 4( AIC, HQ). When in run Diebold model with 4 lag then an error message comes "Near singular matrix'. No such error msg come when i run this model with 1 lag. Should i use lag order 1?
3. After running this Diebold model on return series with lag order 1, spilloverindex file and each PS_ _ file does not show any value. 'NA" only. I don't know why.
4. Last question, if I want to check volatility spillover instead of return spillover then what should be endogenous variable.
Thank You
harpreet_kaur
Postby harpreet_kaur » Sun Jul 21, 2019 10:46 pm
harpreet_kaur wrote:Hi, i have applied Diebold model in Eview9 to check return spillover among five return series ( daily data, around 3000 observation). I have some queries
Thank You
Can anybody please help. I am facing above problems while running dyindex
QAMU
Postby QAMU » Thu Oct 17, 2019 7:21 pm
does this add-in option also estimates the spillovers of diebold and yilmaz (2014) ?
dlodlod
Postby dlodlod » Mon Nov 11, 2019 1:57 am
dakila wrote:Did you read the instruction document ? (dyindex.pdf file located in add-in folder)
You cant run the add-in from the VAR. You should open it first from Add-ins menu. Or try command line.
Yes, I read it. My mistake there, I do not run the add-in from the VAR. I open the Add-in from the Add-ins menu. But I figured out what I was doing wrong. Thank you for your response.
yellow122
Postby yellow122 » Tue Apr 28, 2020 7:38 pm
Thank you for the add-in. I get into trouble when i try to run this function. i don't konw how to fill the option "Svector of variables" when i'm doing generalized. I find that i can get the results with this option in blank, but i don't know how does this option work. Our results will be affected by this option?
Return to “Add-in Support”
Users browsing this forum: No registered users and 11 guests
