scenario command - desc option
Postby tvonbrasch » Thu Apr 12, 2018 5:10 am
I am having trouble with understanding the DESC option in the SCENARIO command. Running the code:
wfcreate u 100
   genr x=50+0.03*@trend+2*nrnd
   genr log(y)=3*log(x)+nrnd
model _m
   _m.append 0*x+log(y)=3*log(x)
_m.scenario(n,a="_1") "scenario 2"
works fine. However, If you replace the last line with
_m.scenario(n,a="_1",desc="test") "scenario 2"
I get the error message:
How should one use the desc option? When I do this manually in the model object (i.e., change the description of a scenrio) I get the following code in the CAPTURE window:
_m.scenario(desc="test", usedesc) "scenario 1"
But this code does not work if I include it in the program.....?
Can you please take a look at it?
Re: scenario command - desc option
Postby EViews Gareth » Thu Apr 12, 2018 7:52 am
Looks like a bug, we'll fix.
Return to “Models”
