Dependency graph view
zezza
Postby zezza » Wed Mar 07, 2018 4:18 am
The new tool for viewing the dependency graph in a model is great, and very useful.
I am wondering if it would be possible to fix the layout of a model, so that when adding/removing one or more equations it is possible to visualize the differences.
EViews Matt
Re: Dependency graph view
Postby EViews Matt » Wed Mar 07, 2018 10:06 am
That's certainly a possibility for the future, another good idea to add to the wish list we've collected thus far.
zezza
Postby zezza » Thu Mar 08, 2018 8:00 am
Thank you for your reply!
I guess that, when ADDING equations, the graph inevitably becomes much more complex, and it may not be feasible to keep a layout. However, when DROPPING equations, keeping the layout should be relatively simple.
wirving
Postby wirving » Mon Mar 12, 2018 11:41 am
Would also be helpful to be able to select a node and see all its connections in isolation from the rest of the model (is that already possible?).
EViews Matt
Postby EViews Matt » Mon Mar 12, 2018 12:05 pm
At the moment, the closest feature is the visual highlight of a node and its connections when you mouse over the node. You could always copy the equation for a node into a new model and visualize that new model, but nothing as easy as just a click or two. In future, there may be tools for selecting/filtering/coloring the display at the node/equation level, which could support what you desire.
Return to “Models”
