Import excel data with empty cols
Moderators: EViews Gareth, EViews Jason, EViews Moderator
loulouviews
Postby loulouviews » Fri Jan 12, 2018 4:10 am
I want to import data from Excel files (.xlsx) into EViews.
I can't change the excel files and I can't know in advance the number of columns and rows (or in other words, I want my prg to work for any number of rows and columns).
I am currently using
import(t=excelxml) %file range=%page colhead=1 namepos=first @smpl %debData %lastData
My problem is that some Excel files contains empty columns between columns with data and the EViews parser stop when encountering such empty column, leaving columns on the right not imported.
Is there any way to circumvent this problem ?
Many thanks
PS : I have attached an Excel file which I can't import.
building_total_sa_nace2.xlsx
(889.18 KiB) Downloaded 4 times
Re: Import excel data with empty cols
Postby EViews Gareth » Fri Jan 12, 2018 9:06 am
You're kind of out of luck. You either have to tell EViews both the upper left corner and bottom right corner of the data, or only the upper left and have no blank rows/columns.
loulouviews
Postby loulouviews » Tue Jan 16, 2018 9:58 am
Ok :?
Thank you for answer !
