SVAR long run restrictions code error
Upile
Postby Upile » Wed Dec 06, 2017 5:46 am
I've been trying to impose long run restrictions on a VAR. I want to impose a diagonal F matrix by running the following codes
var varname.ls 1 12 lgdp inflation int_rate
varname.append(svar) @diag(f)
varname.svar
or
varname.append(svar) @f=matrixf ' (having already created matrixf with NAs in the main diagonal)
varname.svar
I get the following error "Illegal specification . Restriction type for SVAR not specified in "DO_ VARNAME.SVAR".
using the code
varname.svar(f=matrixf)
I get the message "Illegal specification . Restriction type for SVAR not specified in "DO_ VARNAME.SVAR(F=MATRIXF)".
Where am I going wrong?
Thanks in advance
Re: SVAR long run restrictions code error
Postby EViews Gareth » Wed Dec 06, 2017 5:59 am
Which version of EViews?
EViews Matt
Postby EViews Matt » Wed Dec 06, 2017 10:04 am
That error arises when you try to use the new EViews 10 SVAR syntax with an earlier version of EViews. You'll have to use the "old" syntax matching your version. You can learn the old syntax from the local EViews help system, e.g., in the object reference for VARs, rather than the online help (which is for the latest version of EViews).
Upile
Postby Upile » Wed Dec 06, 2017 3:00 pm
I’m using eviews 9.
EViews Matt
Postby EViews Matt » Wed Dec 06, 2017 3:17 pm
In which case you'll need to use something like:
varname.svar(rtype=patlr,namelr=matrixf)
Upile
Postby Upile » Wed Dec 06, 2017 6:15 pm
It worked. Thanks guys. I appreciate it
