Importing into transposed data skipping columns
jacarandas
Postby jacarandas » Mon Nov 13, 2017 11:25 pm
I was reading through http://www.eviews.com/help/helpintro.ht ... mport.html. But I can't figure out how can I import in a dataset that is transposed, but with my variable names only starting in Column C, while actual data starts in Column D.
This is what I have done, which imports in the transposed data, but doesn't give the data series a name, and doesn't skip the first two columns as well. If the imported data doesn't skip the first two columns, it offsets the actual date the data starts in.
import ABC.csv "byrow" @frequency q 2001 @smpl 2001Q1 2010Q4
Is there a function similar to skip or how should I be doing this?
Thanks!
Re: Importing into transposed data skipping columns
Postby EViews Gareth » Tue Nov 14, 2017 9:40 am
Did you try colhead=3 ?
Postby EViews Steve » Tue Nov 14, 2017 12:57 pm
If you use our import wizard, you can select which row is the name, and which row is where the data starts. At the end, you'll see the captured command with all the appropriate options.
Users browsing this forum: No registered users and 14 guests
