An introduction to EViews programming.
rileyjiang
Re: An introduction to EViews programming.
Postby rileyjiang » Sun Dec 22, 2013 4:35 pm
Thank you for your reply Gareth. I guess learning/writing algorithm is probably too much for me. I will stay with my old 'technique' for the time being. I might pick it up at a later time for future research though. Thanks for the hints. Regards.
Jirka
Postby Jirka » Thu Dec 26, 2013 9:57 am
Thank you for your reply. I will try it. Merry Christmas and happy New year!
Mamona
Postby Mamona » Fri Jan 03, 2014 10:04 am
I am running the following loop
scalar n=5 'number of time series (y1,y2,.....,90), (x1,x2,.....,90)
scalar ind=1 'input for loop
for !a=1 to 2
vector(N) LMxy 'returns LMstat for volatility spillover from x to y
vector(N) pvalxy 'returns corresponding pvalue for LMxy
Eviews 5.0 is giving an error as
for statement unterminated in For !a=1 to 2
can someone help me in getting this issue resolved?
Postby startz » Fri Jan 03, 2014 10:48 am
Do you have a
statement?
debasishmaitra
Postby debasishmaitra » Fri Feb 14, 2014 9:33 pm
Hi friends,
while I am running the For loop on Eviews 5, I am getting that x{!i} is an illegal or not defined. The programmes written is as follows;
'after data upload and Y and each X are defined.
'run pairwise regressions between Y and each X
for !i=1 to 15
equation eq{!i}.ls y c x{!i}
Please help me out on this
Thanking you,
Regards,
Debasish
Postby EViews Gareth » Fri Feb 14, 2014 9:57 pm
To be honest, EViews 5 is so old, I don't think anybody is going to be able to help. It doesn't even install on modern OSs.
ChockalingamKC
Postby ChockalingamKC » Fri Feb 21, 2014 10:32 am
EViews Gareth. Thanks for the detailed post.
1) Is there any reference manual to learn Eviews programming.
2) any training Eviews can provide to get familiarity with Eviews Programming.
Postby EViews Gareth » Fri Feb 21, 2014 10:57 am
The Command and Programming Reference (pdf available from the Help menu) has a chapter on programming.
Better are our two programming webinars:
http://www.eviews.com/Training/Prog1.html
http://www.eviews.com/Training/Prog2.html
Or, if those dates don't suit you, you can organise a custom date for you by emailing training@eviews.com
patsman
Postby patsman » Wed Jun 04, 2014 10:06 am
¿Cómo guardo los pasos que hago en eviews, en un program de eviews?
Postby EViews Gareth » Wed Jun 04, 2014 10:21 am
Currently there is no way to do that.
student07
Postby student07 » Sat Jun 07, 2014 7:56 am
Is there a way to pass arguments to a program that I run using the 'exec' keyword? I know that I can of course define a variable before, but in that case the variable remains in the workspace (unless I delete it at least). Is it not in a way possible to do something like 'exec program.prg x=5' (to pass the argument x=5)?
Postby EViews Gareth » Sat Jun 07, 2014 8:21 am
Yes. Look up program arguments in the command and programming reference pdf
anhkhoa_lpt
Postby anhkhoa_lpt » Mon Aug 04, 2014 5:52 am
How can I store P value (or t-statistics) from Dickey fuller test to a matrix. I have more than 50 series, so I want to use code to improve my productivity. Tks a lot.
Postby EViews Gareth » Mon Aug 04, 2014 6:19 am
newbie1985
Postby newbie1985 » Sat Aug 16, 2014 5:21 am
Hello, I am new user of eviews and econometrics in general and I have two questions. I have a similar task like the quoted post but the difference is that I would like to run regressions with hac errors and to store in a matrix more information than just the coefficients. I would like to store in a matrix coefficients, p values and r squared. However, before running regressions I applied unit root test and as most variables - not all- had unit root I applied the first difference for all variables. I applied again unit root test and now I cannot find unit root for any variable. I do not know if this is totally correct but please correct me if not. As I have done this process I am not sure if I should include the term c in my simple regressions. Could anyone help me with this please? Thank you in advance.
Diederick wrote:Dear all,
I am following this topic in order to write a short program to estimate market model regressions.
I have 100 dependent variables , named Y 1-100
and 100 independent variables , named x 1-100.
I would like to regress all the dependent variables y on a constant and the corresponding x.
So equations: y1 c x1 ,y2 c x2 etc.
Then I would like to store all the coefficients of c and x(i) in a matrix.
I have written the following program, which works for the regressions but does not succeed in storing the coefficients.
matrix(2,100) coefs
equation eq
for !i=1 to 100
for !j=1 to 100
if !i=!j then
equation eq{!i}_{!j}.ls y{!i} c x{!j}
colplace(coefs, eq.@coefs, !i)
endif
Could anyone tell me what is wrong here? Thanks in advance for your answer!
Users browsing this forum: No registered users and 21 guests
