Question about NA in model result and endogenous variable
andiejia
Postby andiejia » Thu Feb 11, 2016 5:45 pm
I try to solve for this model
I use the instrument variable to solve for each equation.
m_s, p and gov are all exogenous variables while others are endogenous variables.
Now the problem is that there are some NA in results and r_l is an exogenous variable rather than endogenous variable.
Also, p suppose to be an exogenous variable but it does not show in the model.
Thank you so much and I really appreciate your help.
model1.wf1
(39.86 KiB) Downloaded 130 times
Re: Question about NA in model result and endogenous variabl
Postby EViews Gareth » Fri Feb 12, 2016 9:37 am
I don't really understand what you're asking/saying.
The model in that workfile has 5 equations.
  • gdp = cons + inv + gov
  • m = m_s
  • m_p = -25977.6 + 0.0233*gdp- 9155.3*r_l + (ar term)
  • cons = 1140319.6 + 0.310567*gdp + (ar term)
  • inv = -410824.3 - 70748.35*r_l + 6.61*D(gdp(-1)) + (ar term)
No where is "p" mentioned. Clearly gov, m_s and r_l are exogenous variables, and everything else is endogenous.
Return to “Models”
