Modify graph axis
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
hakperest
Modify graph axis
Postby hakperest » Fri Sep 11, 2015 4:08 am
Hello ,
I have a graph that was plotted
graph gr.line
command. I want modify bottom axis that should be as like as following image. Bottom axis may contain only ordered number (without zero or decimal pointers). How can I do that?
Huseyin
Re: Modify graph axis
Postby EViews Jason » Fri Sep 11, 2015 8:56 am
We are going to need more context. If you have an undated workfile this should already happen, unless I am completely missing what you are asking.
Posting your workfile or an example workfile would be helpful.
hakperest
Postby hakperest » Sat Sep 12, 2015 12:44 pm
My code is:
 graph gr_multi.line(a)  new
gr_multi.shade(shade, left) 0
gr_multi.options linepat
gr_multi.setelem(2) lcolor(black) lwidth(2) lpat(1)
and my file is attached.
I need my graph be scaled automatically.
Ploted series have restricted sample and contains only 40 length then bottom axis should be start with zero and continiues until 40.
eviewstest.wf1
(20.23 KiB) Downloaded 442 times
Postby EViews Jason » Mon Sep 14, 2015 9:38 am
You will have to create a series with the desired labels and then create a XY line graph.
load eviewstest
series trend=@trend
series index = trend-@first(trend)  'create an index series starting at the beginning of the sample
group mygroup  index new
freeze(gr_multi2) mygroup.xyline
hakperest
Postby hakperest » Fri Sep 18, 2015 10:20 am
Your code was great but there is some other problems with this method.
I used following codes and graph shows more timeset. I want it show only bottom axis between zero and 80 but this method shows it within -10 and 90. Where my data includes only zero to 80.
          %trend=@getnextname("ZZ__trend")
     %index=@getnextname("ZZ__index")
     %mygroup=@getnextname("ZZ__mygroup")
     series {%trend}=@trend
     series {%index} = {%trend}-@first({%trend})-1
     %legendArti=%i+ " +"
     %legendEksi=%i+ " -"
 ' graph {%graph}.line {%i}_2_0m -{%i}_2_0m ({%i}_2_0m -{%i}_2_0m)
     group {%mygroup}  {%index}   {%i}_2_0m -{%i}_2_0m ({%i}_2_0m -{%i}_2_0m)
       freeze({%graph}) {%mygroup}.xyline
      {%graph}.shade(shade, left) 0
      {%graph}.options linepat
      {%graph}.setelem(1) lcolor(black) lwidth(3) lpat(2) legend()
      {%graph}.setelem(2) lcolor(black) lwidth(2) lpat(1)legend({%legendArti})
      {%graph}.setelem(3) lcolor(red) lwidth(2) lpat(1) legend({%legendEksi})
      {%graph}.setelem(4) lcolor(red) lwidth(1) lpat(2) legend(diff)
      {%graph}.setelem(5) lcolor(red) lwidth(1) lpat(2)legend()
      {%graph}.setelem(6) lcolor(red) lwidth(0) lpat(2) legend()
      {%graph}.options size(4,2) -inbox
      {%graph}.legend position(botcenter)
Postby EViews Jason » Fri Sep 18, 2015 4:05 pm
Your sample code does not run for me. I am missing some series such that the following line gives an error
In any case, in your code you also have
Did you mean to add the '-1'. If you remove it I believe it will fix the problem
hakperest
Postby hakperest » Sat Sep 19, 2015 2:16 am
Thanks a lot. My problem solved with changing smpl :)
Bu I found an bug about plotting with xyline command.
xyline command ignores first series when it plot and colourized but start from first (trend in this example) when legend command is used.
%graph="linegraph"
d {%graph}
graph {%graph}.line x1 x2 x3
        {%graph}.setelem(1) lcolor(black) lwidth(2) lpat(2) legend(x1)
        {%graph}.setelem(2) lcolor(black) lwidth(2) lpat(1)legend(x2)
        {%graph}.setelem(3) lcolor(red) lwidth(2) lpat(1) legend(x3)
  group  mygroup  trend  x1 x2 x3
   %graph="xylinegraph"
       freeze({%graph})  mygroup.xyline
test.wf1
(36.71 KiB) Downloaded 393 times
Postby EViews Jason » Tue Sep 22, 2015 8:07 am
Trend isnt being ignored, it is the x axis. So it will not appear as another line. You are graphing trend vs x1, trend vs x2 and trend vs x3. So this appears correct.
Because Trend is the first element in the group, when setting the legend labels for the other series you have to skip Trend. This I admit may not be intuitive but I think you want
{%graph}.setelem(2) lcolor(black) lwidth(2) lpat(2) legend(x1)
        {%graph}.setelem(3) lcolor(black) lwidth(2) lpat(1)legend(x2)
        {%graph}.setelem(4) lcolor(red) lwidth(2) lpat(1) legend(x3)
Return to “Add-in Writing area”
