bivariate normals
bivariate normals
Postby startz » Thu Apr 30, 2015 9:44 am
The following code is a subroutine that generates bivariate normal series with zero means. Note that since it is a subroutine, it can only be called from a program.
'   Generate bivariate mean zero normals
'   Dick Startz
'   April 2015
subroutine bivariateNormals(series e1,series e2,scalar sigma1,scalar sigma2,scalar rho)
'   return series e1 and e2 with standard deviations sigma1 and sigma2 and correlation rho
'   e1 and e2 must be defined as series in workfile. The other parameters are scalars.
if abs(rho)>1 then
   seterr "correlation must be between -1 and 1"
   return
endif
e1 = sigma1*nrnd
e2 = sigma2*(rho*e1/sigma1 + @sqrt(1-rho^2)*nrnd)
endsub
NicolasR
Re: bivariate normals
Postby NicolasR » Fri Jul 17, 2015 10:31 am
Thanks for the code, I'm using it to run some multivariate simulations, but I have a question, the code is based in the method that use the cholesky decomposition?
Regards.
Postby startz » Fri Jul 17, 2015 10:43 am
Yes
