Dubin 1998 Replication
CharlieEVIEWS
Postby CharlieEVIEWS » Thu Apr 16, 2015 1:02 pm
This code replicates part of Dubin (1998) - Spatial Econometrics, A Primer. The .txt attachment is the values of their (simulated) distance matrix (to check for congruence of results). Please feel free to post any questions below and I'll do my best to answer.
Charlie
''This is a file to replciate the first half (SEM part) of Dubin (1998) in JoHE
%cd = Change your CD here
'Set up the distance matrix
wfcreate(wf=durbinreplication) u 1
matrix(10,10) distance
distance.read {%cd}\durbindistance.txt
!lamda1 = 0.33
!lamda2 = 0.67
for !l = 1 to 2
   for !p = 1 to 3
      matrix(@rows(distance),@columns(distance)) w_{!p}_{!l}
      for !a = 1 to @rows(w_{!p}_{!l})
         for !b = !a to @rows(w_{!p}_{!l})
            if !a<>!b then
               w_{!p}_{!l}(!a,!b)=1/distance(!a,!b)^(!p)
               w_{!p}_{!l}(!b,!a)=w_{!p}_{!l}(!a,!b)
            endif
         !temp = @csum(@transpose((w_{!p}_{!l})))(!a)
         for !b = 1 to @rows(w_{!p}_{!l})
            if !a<>!b then
               w_{!p}_{!l}(!a,!b)=w_{!p}_{!l}(!a,!b)/!temp
            endif
      matrix V_{!p}_{!l}   = @inverse(@identity(10)-(!lamda{!l}*w_{!p}_{!l}))*@inverse(@identity(10)-(!lamda{!l}*(@transpose(w_{!p}_{!l}))))
      matrix(@rows(V_{!p}_{!l}),@columns(V_{!p}_{!l})) C_{!p}_{!l}
      for !a = 1 to @rows(C_{!p}_{!l})
         for !b = !a to @rows(C_{!p}_{!l})
            C_{!p}_{!l}(!a,!b)=V_{!p}_{!l}(!a,!b)/@sqrt(V_{!p}_{!l}(!a,!a)*V_{!p}_{!l}(!b,!b))
      matrix(((@rows(C_{!p}_{!l})-1)*@rows(C_{!p}_{!l}))/2,2) output_matrix_{!p}_{!l}
      !c = 0
            if !a<>!b then
               !c = !c+1
               output_matrix_{!p}_{!l}(!c,2)=C_{!p}_{!l}(!a,!b)
               output_matrix_{!p}_{!l}(!c,1)=distance(!a,!b)
            endif
      freeze(output_graph_{!p}_{!l}) output_matrix_{!p}_{!l}.scat
      show output_graph_{!p}_{!l}
dubindistance.txt
(466 Bytes) Downloaded 161 times
