Automatic ARMA selection
Felipe
Re: Automatic ARMA selection
Postby Felipe » Thu Nov 09, 2017 9:21 am
Thanks for your answer.
I want the same program, the automatic ARMA selection, but the program posted in this forum consider a regression with constant.
Here:
equation {%eqname}.ls dlog({%dep}) {%regs} {%lagstring} {%mastring}
Where:
 {%regs}
is the constant.
So I want a regression without this parameter
 {%regs}
I thought if I stablished a conditional I could resolve this problem, because I need to avoid a regression without parameters.
The first conditional considers the case without ARMA terms. So the regression is with constant:
if %arstring="ar(0)" and  %mastring="ma(0)" then
      equation {%eqname}.ls(arma=cls, optmethod=legacy) {%dep} {%regs}
endif
The second conditional considers the case with ARMA terms without constant:
if %arstring="ar(1)" or %arstring="ar(2)" or  %arstring="ar(3)" or  %arstring="ar(4)" or %mastring="ma(1)" or %mastring="ma(2)" or %mastring="ma(3)" or %mastring="ma(4)"  then
       equation {%eqname}.ls(arma=cls, optmethod=legacy) {%dep} {%arstring}{%mastring}
endif
But this conditionals doesn't work.
Postby EViews Gareth » Thu Nov 09, 2017 9:22 am
'Create some data.  Delete these first few lines if you want to run on your existing workfile.
create u 1000
series y=nrnd
'Program that calculates the "best" ARMA specification for an equation.  Edit the variables below to match your particular data/setup.
%eqname = "EQ01"   'name of equation object that will be used.
%maxAR = "2"            'maximum number of AR terms
%maxMA = "3"   'maximum number of MA terms
%dep = "Y"   'dependent variable
%regs = " "   'independent variables
%criterion = "@AIC"    'which criterion to use  enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn
!maxAR = @val(%maxAR)
!maxMA = @val(%maxMA)
close {%eqname}
'create table for storing critical values.
%matname = "crits"
if @isobject(%matname) then
   %matname = "__crits"
      delete {%matname}
   endif
endif
table(!maxar+2,!maxma+2) {%matname}
{%matname}(1,1) = "AR /  MA"
{%matname}.setlines(1) +b
{%matname}.setlines(a) +r
'set sample
smpl @first+!maxAR @last
!mincrit = 1e12  'set the minimum to an artificially large value to begin
'estimate the models
%arstring = ""
for !i=0 to !maxar
   'build up string for AR terms.
   if !i>0 then
      %arstring = %arstring + " ar(" + @str(!i) + ")"
   endif
   %mastring = ""
   for !j=0 to !maxma
      'build up string for MA terms
      if !j>0 then
         %mastring = %mastring + " ma(" + @str(!j) + ")"
      endif
      'estimate equation
      %allregs = %regs + %arstring + %mastring
      if @len(%allregs)>1 then
         equation {%eqname}.ls {%dep} {%regs} {%arstring} {%mastring}
         'capture criterion
         if @upper(%criterion) = "@AIC" then
            !crit = {%eqname}.@aic
         endif
         if @upper(%criterion) = "@SCHWARZ" then
            !crit = {%eqname}.@schwarz
         endif
         if @upper(%criterion) = "@HQ" then
            !crit = {%eqname}.@hq
         endif
         'compare criterion
         if !crit < !mincrit then
            !mincrit = !crit
            !bestAR = !i
            !bestMA = !j
            %bestARstr = %arstring   'store the best ar string
            %bestMAstr = %mastring   'store the best ma string
            {%matname}.settextcolor(@all) black   'table formatting.
            !ii=!i+2
            !jj=!j+2
            {%matname}.settextcolor(!ii,!jj) red
         endif
         {%matname}(!i+2,!j+2) = !crit
         {%matname}(!i+2,1) = !i
         {%matname}(1,!j+2) = !j
      endif
equation {%eqname}.ls {%dep} {%regs} {%bestARstr} {%bestMAstr}
show {%eqname}
show {%matname}
sazad
Residuals from an AR(1) for a number of macroeconomic variables & countries
Postby sazad » Wed Feb 14, 2018 4:24 pm
I have not programmed much in E-views, so not an export. I am trying to obtain absolute values of residuals from an AR(1) model for time series data of more than one macroeconomic variable and country in one go. Attached a test file for just one variable. How can I create a loop to store the abs value for each of the macro variables for each country? Any prompt help is much appreciated.
Many thanks,
Sohel
macro.xlsx
(16.24 KiB) Downloaded 89 times
