Quantile Regresssion on Panel data
Ashish Garg
Postby Ashish Garg » Mon Mar 09, 2015 11:33 pm
I am not familiar with high level mathematics, i want to apply quantile regression on stacked panel data. option is available in eviews 8. i have applied the same on my data and calculated the results i have not sure results are valid or not as such no literature is available on quantile regression on panel data. please help me.
Re: Quantile Regresssion on Panel data
Postby EViews Glenn » Tue Mar 10, 2015 7:26 am
The quantile regrssion in a panel structured workfile is simply pooled estimation. It takes no account of the panel structure of your data.
Ashish Garg
Postby Ashish Garg » Tue Mar 10, 2015 10:28 pm
Dear Sir
thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
Ashish Garg
Postby Ashish Garg » Wed Mar 18, 2015 5:19 am
EViews Glenn wrote:The quantile regrssion in a panel structured workfile is simply pooled estimation. It takes no account of the panel structure of your data.
Thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
Postby EViews Glenn » Wed Mar 18, 2015 3:39 pm
It's a pooled. There is no account taken of the time or cross-section of a given observation.
olayenidynare
Postby olayenidynare » Wed May 02, 2018 4:38 am
Good afternoon
Suppose I write the following code:
equation qpanel.qreg y x @expand(var01)
or
equation qpanel.qreg y x c @expand(var01,@dropfirst)
won't that be equivalent to panel with fixed effect?
I'm just curious about it.
Users browsing this forum: No registered users and 18 guests
