BPTest (Breusch-Pagan LM test for random effects)
Moderators: EViews Moderator, EViews Gareth, EViews Esther
Postby EViews Gareth on Fri Apr 16, 2010 11:10 am
This thread is about the BPTest Add-in that calculates the Breusch-Pagan LM test for random effects.
Change Log
  • 2010/04/16 - Initial Release
  • 2010/04/28 - Fixed documentation file name
  • 2010/08/16 - Fix for unbalanced panels / equations that don't use every cross-section in the panel
  • 2010/11/02 - Added an error message to indicate that the equation should be estimated without cross-section effects prior to running the test.
  • 2010/11/24 - Added Honda (1985), King and Wu (1997), SLM (Moulton and Randolph, 1989), GHM (Gourierouxet al., 1982) LM tests.
  • 2012/05/10 - Edited the BPtest documentation; Added a command for exclusion of tests.
  • 2012/09/26 - Minor changes made.
Re: BPTest (Breusch-Pagan LM test for random effects)
Postby EViews Gareth on Wed Apr 28, 2010 3:51 pm
The documentation file in this add-in had the wrong name. That has now been fixed.
BP LM Test for Random Effects Add-in
Postby y.khairulin on Fri Aug 13, 2010 12:41 am
Hi guys,
I've just installed the LM test for Random Effects add-in .
When I run this add-in from equation object (Proc->Add-ins->Breusch-Pagan Random Effects LM test) it returns an error saying: Log or square root of negative number.
I do not understand where the problem may come from, any advice?
Thanks.
y.khairulin
Re: BP LM Test for Random Effects Add-in
Postby y.khairulin on Fri Aug 13, 2010 4:36 am
Btw, I'm using 7th version of Eviews
y.khairulin
Postby EViews Gareth on Fri Aug 13, 2010 8:03 am
Could you post your workfile with the equation in question?
Postby y.khairulin on Sat Aug 14, 2010 2:42 am
Please find attached the workfile with equation.
Thanks.
regression_main.wf1
(1.95 MiB) Downloaded 323 times
y.khairulin
Postby EViews Gareth on Sat Aug 14, 2010 10:31 am
There's something odd about that equation. Did you copy it from another workfile, or add data to the workfile after estimating it?
It is no longer estimatable.
Postby y.khairulin on Sat Aug 14, 2010 7:10 pm
I resampled it and included less periods due to large size of the file.
This is the workfile for the full sample, I used 7zip to compress, hope this works.
Btw, thx for the fast reply.
regression_main.7z
(1.93 MiB) Downloaded 250 times
y.khairulin
Postby ralf on Mon Aug 16, 2010 7:18 am
Hi, I have the same problem, is there already a solution? Thanks, Ralf
ralf
Postby EViews Gareth on Mon Aug 16, 2010 8:47 am
Working on it...
The way it is currently calculating things will only work on panel equations that use every cross-section in the workfile. I'm trying to figure out how to get it to work on equations that only use some cross-sections.
Postby EViews Gareth on Mon Aug 16, 2010 2:41 pm
Try re-downloading the add-in. I think this one should work (for you both?)
Postby y.khairulin on Tue Aug 17, 2010 2:00 am
Thanks for your help in resolving this problem Gareth.
Everything works fine.
y.khairulin
Postby ralf on Tue Aug 17, 2010 1:29 pm
Yes, it's working. Thanks!
ralf
Postby EViews Gareth on Tue Aug 17, 2010 1:34 pm
Great.
Postby EViews Esther on Wed Nov 24, 2010 11:52 am
[Updates in the BPtest add-in]
(1) Added Honda (1985), King and Wu (1997), SLM (Moulton and Randolph, 1989), GHM (Gourierouxet al., 1982) LM tests.
(2) Considered either joint test for both cross-section and period eff ects or one-sided test for one e ffect.
EViews Esther
Next
Return to Add-in Support
