ZAURoot (Zivot-Andrews Unit Root test)
Postby EViews Gareth » Mon Apr 05, 2010 1:55 pm
This thread is about the ZAURoot Add-in that performs the Zivot-Andrews Unit Root (1992) test with single structural break.
yezitian1987
Re: ZAURoot (Zivot-Andrews Unit Root test)
Postby yezitian1987 » Thu Apr 22, 2010 10:28 am
Thank you very much!! But I do not know how to use it. What does format string mean? Could it be used in EVIEWS6?
Postby EViews Gareth » Thu Apr 22, 2010 10:30 am
As with all Add-ins, this requires EViews 7.1 or above.
rbanaco
Postby rbanaco » Tue Apr 27, 2010 9:58 am
hy I have eviews 7.1 and this add in installed but I get "insufficient number of observations" ... what can I do? I'm testing unit root for GDP and some other variables of portugal between 1960-2008 and I can't perform this test... can anyone help me? thank you in advance
Postby EViews Gareth » Tue Apr 27, 2010 9:59 am
Could you post your workfile?
rbanaco
Postby rbanaco » Tue Apr 27, 2010 10:17 am
ok here it is
the tests are for "lpibpc" and some others but let's start from there
dados em eviews.wf1
(68.82 KiB) Downloaded 1872 times
Postby EViews Gareth » Tue Apr 27, 2010 3:43 pm
Just to confirm, when you execute the following command:
equation temp.ls d(lpibpc) lpibpc(-1) c @trend d(lpibpc(-1)) d(lpibpc(-2))
on the workfile you just posted, you get the same "insufficient observations" error?
Postby EViews Gareth » Thu Apr 29, 2010 12:03 pm
-------------Deleted posts here, which involved discovering the problem was not add-in related-------------
Postby EViews Gareth » Thu Apr 29, 2010 5:28 pm
Ok, it is definitely not related to this add-in, so I'm going to remove the posts from here and move it to email.
rbanaco
Postby rbanaco » Fri Apr 30, 2010 5:11 pm
hy there! I fixed it.. the problem was the program itself don't know why but i uninstalled and cleaned all the registry entries of it and the folders in appdata and now it works like charm thank you for your patience and time I appreciated it..
penumbra
Postby penumbra » Thu May 27, 2010 8:28 am
I am having exactly the same problem as the user above. i have a workfile with a series (rids) consisting of 129 observations. if i attempt to run the zauroot test on it, regardless of how many lags i specify, I receive the insufficient number of observations error.
the same works for command line. typing in rids.zauroot results in the same error.
ps. eviews 7.1
edit. having downloaded the previous user's workfile, I receive the same insufficient number of observations error performing the test on his series
excel data.wf1
(9.24 KiB) Downloaded 1279 times
Postby EViews Gareth » Thu May 27, 2010 8:32 am
Could you email me (support@eviews.com) your workfile and your EViews serial number?
mofar
Postby mofar » Wed Aug 18, 2010 12:36 am
Can you please let me know how one should interprete the results of ZA unit root test in EViews? P-value of this test can show us the acceptance of H0:unit root?
thanks
reza
ahaia1930
Postby ahaia1930 » Thu Aug 26, 2010 8:47 pm
URGENT
Got a problem. Want to use Z-A test. have 37 obervations. For all the series, get near singular matrix error - irrespective of lag and whether C, T or C&B option is sued. How to fix it? using Eviews 7.1.
erburcu81
Postby erburcu81 » Tue Sep 21, 2010 3:46 am
I am trying to download ZAURoot adds in to my computer.l i have Eviews 6. It wants me to write something in the Format String part and I could not skip that part.
Could you please expalin me what to do?
Return to “Add-in Support”
Users browsing this forum: No registered users and 10 guests
