TechAsis (Technical Analysis)
Postby EViews Gareth » Mon Apr 05, 2010 1:50 pm
This thread is about the TechAsis that allows you to perform various technical analysis techniques on stock data. Note this Add-in package includes the GetStocks add-in.
Change log
  • 2010/02/10 - Initial release
  • 2010/04/07 - Added better error handling for invalid stock symbols in the GetStocks add-in
  • 2010/04/30 - Remove Chaikin's Volatility
  • 2010/05/04 - Fixed installer to have link to documentation file.
  • 2010/05/10 - Added a command line interface to the GetStocks add-in
utah777
Re: TechAsis (Technical Analysis)
Postby utah777 » Tue Aug 07, 2012 3:14 am
Bollinger Bands:
1. It seems that the default series OUT_HIGH should be renamed OUT_LOW as it provides values for lower boundary (the same for OUT_LOW, change the name to OUT_HIGH)
2. The resulting default graph OUT_G that appears at the end of analysis would become more meaningful if you add the series for the underlying price, instead of calculated moving average.
Return to “Add-in Support”
