Exec and directory
Sharky
Exec and directory
Postby Sharky » Tue Dec 19, 2023 11:39 am
This is very strange and I can't see what I'm doing wrong.
The code
cd "<...>\PhD version files"
<various minor routines>
exec ".\create all appex v5.prg"
When I run it, I get an error saying that the program 'create all appex v5.prg' isn't found on disk in a totally different place!
<...>DOCUMENTS\EVIEWS ADDINS\CREATE ALL APPEX V5.PRG not found on disk in "EXEC ".\CREATE ALL APPEX V5.PRG"" on line 35.
I reset with cd directly and try running that line but each time it thinks I'm trying to call a program from an 'eviews addins' folder for some reason.
The status line has the correct Path.
I'm running Eviews 12 University Edition
Re: Exec and directory
Postby EViews Gareth » Tue Dec 19, 2023 11:55 am
Sharky
Postby Sharky » Wed Dec 20, 2023 2:34 am
EViews Gareth wrote:https://eviews.com/download/whitepapers/ExecInclude.pdf
Thanks Gareth. Any idea why it's calling from addins even though I'm using
Postby EViews Gareth » Wed Dec 20, 2023 8:16 am
Is the program you are running from saved to disk?
Sharky
Postby Sharky » Wed Dec 20, 2023 8:39 am
EViews Gareth wrote:Is the program you are running from saved to disk?
Yes, saved to and running from C drive.
Postby EViews Gareth » Wed Dec 20, 2023 8:57 am
Is your copy of EViews up to date?
Sharky
Postby Sharky » Wed Dec 20, 2023 10:05 am
EViews Gareth wrote:Is your copy of EViews up to date?
I downloaded Eviews 12 University edition about a month ago - is that up to date?
Postby EViews Gareth » Wed Dec 20, 2023 10:34 am
Should be.
Seems strange.
Can you do the following:
  • Create a brand new program.
  • Enter a single line:
    exec ".\foo.prg"
  • Save as "c:\temp\test.prg" (make sure you have a folder called test)
  • Run
It should error saying "c:\temp\foo.prg not found"
Sharky
Postby Sharky » Wed Dec 20, 2023 12:38 pm
EViews Gareth wrote:Should be.
Seems strange.
    exec ".\foo.prg"
  • Run
Not sure what you mean by 'a folder called test' but I saved in both the location specified and a subfolder called 'test'. In both cases I got the error:
C:\TEMP\TEST\FOO.PRG not found on disk in "EXEC ".\FOO.PRG"" on line 1.
C:\TEMP\FOO.PRG not found on disk in "EXEC ".\FOO.PRG"" on line 1.
Postby EViews Gareth » Wed Dec 20, 2023 12:40 pm
ok, so that appears to be working correctly. Something specific about your program is causing the weird behaviour.
(and I mean to say a folder called "temp". My bad)
Sharky
Postby Sharky » Thu Dec 21, 2023 6:56 am
OK I've replaced with include and for some reason it works. Very strange.
Users browsing this forum: No registered users and 16 guests
