tvgc add-in
kzmh78
tvgc add-in
Postby kzmh78 » Mon Dec 21, 2020 1:55 am
Hi, When I run a tvgc add-in and check the tvgc.pdf's example using moneyincome.wf1,
then I got a error message 'Error 17 in encrypted program'.
What could be the cause?
dakila
Re: tvgc add-in
Postby dakila » Mon Dec 21, 2020 3:49 pm
It requires the version 12.
kzmh78
Re: tvgc add-in
Postby kzmh78 » Tue Dec 22, 2020 3:35 am
Thank you for your Comment. I used version 11.
dakila
Re: tvgc add-in
Postby dakila » Fri Dec 25, 2020 6:40 am
This thread is about the TVGC add-in that estimates subsample tests (a forward recursive algorithm, a rolling window algorithm, and a recursive evolving algorithm) of Granger causality within a lag-augmented vector autoregressive framework (pleases see Shuping, Hurn and Phillips, 2020).
KamrulHassan
Re: tvgc add-in
Postby KamrulHassan » Wed Jan 13, 2021 9:02 am
I am using EViews 12; however, could not install tvgc, it says 'installation of tvgc failed'. How can I install tvgc?
KamrulHassan
Re: tvgc add-in
Postby KamrulHassan » Wed Jan 13, 2021 6:29 pm
Hi there,
I was able to install 'tvgc'; however, could not run, it returns an error message like "Error 1663 encrypted program"; is there a solution to this problem? I am using EViews 12.
Thank you.
Kamrul Hassan
dakila
Re: tvgc add-in
Postby dakila » Thu Jan 14, 2021 9:47 am
can you run the example file (tvgc_ex.prg)?
KamrulHassan
Re: tvgc add-in
Postby KamrulHassan » Fri Jan 15, 2021 8:35 am
No such example file is installed in the folder. Where can it be found? Thanks.
dakila
Re: tvgc add-in
Postby dakila » Fri Jan 15, 2021 8:50 am
C:\Users\...\Documents\EViews Addins\tvgc
KamrulHassan
Re: tvgc add-in
Postby KamrulHassan » Fri Jan 15, 2021 10:28 am
Thank you so much, yes, I was able to run the program file 'tvgc_ex.prg', however, when tried to implement 'tvgc' with example work file 'moneyincome', it again returns error message. Any help would be much appreciated. Thank you.
harlon1976
Re: tvgc add-in
Postby harlon1976 » Sat Jan 16, 2021 6:15 pm
I find the critical value for a given significant level is constant for all estimated sample.But I think it is different for different time .Is that ture?
dakila
Re: tvgc add-in
Postby dakila » Sun Jan 17, 2021 12:14 am
I am not sure about your question. You should ask the question from authors of paper: Shuping Shi or Peter Phillips
KamrulHassan
Re: tvgc add-in
Postby KamrulHassan » Sun Jan 17, 2021 6:59 am
I can open 'tvgc' add-in in the example workfile 'moneyincome'; however, after specifying the model when I click OK, it return an error message. However, I cannot open the 'tvgc'add-in in EViews workfile with my own data, it again returns an error message. I hope I was able to make it clear this time. Any help is highly appreciated. Thank you.
dorada
Re: tvgc add-in
Postby dorada » Tue Nov 02, 2021 7:55 pm
Hello, I have a problem with executing the model, I get a message 'Error 17 in encrypted program.Before, I manage the work with the example files, however when I try to my own data I get this warnings.Thank you
dakila
Re: tvgc add-in
Postby dakila » Fri Nov 05, 2021 5:17 am
I think you should change your data to time series data if your data is undated.
Return to “Add-in Support”
Users browsing this forum: No registered users and 31 guests
