Hi, When I run a tvgc add-in and check the tvgc.pdf's example using moneyincome.wf1,
then I got a error message 'Error 17 in encrypted program'.
What could be the cause?
tvgc add-in
Re: tvgc add-in
Thank you for your Comment. I used version 11.
Re: tvgc add-in
This thread is about the TVGC add-in that estimates subsample tests (a forward recursive algorithm, a rolling window algorithm, and a recursive evolving algorithm) of Granger causality within a lag-augmented vector autoregressive framework (pleases see Shuping, Hurn and Phillips, 2020).
Re: tvgc add-in
I am using EViews 12; however, could not install tvgc, it says 'installation of tvgc failed'. How can I install tvgc?
Re: tvgc add-in
Hi there,
I was able to install 'tvgc'; however, could not run, it returns an error message like "Error 1663 encrypted program"; is there a solution to this problem? I am using EViews 12.
Thank you.
Kamrul Hassan
Thank you.
Kamrul Hassan
Re: tvgc add-in
can you run the example file (tvgc_ex.prg)?
Re: tvgc add-in
No such example file is installed in the folder. Where can it be found? Thanks.
Re: tvgc add-in
C:\Users\...\Documents\EViews Addins\tvgc
Re: tvgc add-in
Thank you so much, yes, I was able to run the program file 'tvgc_ex.prg', however, when tried to implement 'tvgc' with example work file 'moneyincome', it again returns error message. Any help would be much appreciated. Thank you.
Re: tvgc add-in
I find the critical value for a given significant level is constant for all estimated sample.But I think it is different for different time .Is that ture?
Re: tvgc add-in
I am not sure about your question. You should ask the question from authors of paper: Shuping Shi or Peter Phillips
Re: tvgc add-in
I can open 'tvgc' add-in in the example workfile 'moneyincome'; however, after specifying the model when I click OK, it return an error message. However, I cannot open the 'tvgc'add-in in EViews workfile with my own data, it again returns an error message. I hope I was able to make it clear this time. Any help is highly appreciated. Thank you.
Users browsing this forum: No registered users and 10 guests
