actexist
actexist
Postby tvonbrasch » Thu Aug 20, 2020 12:39 am
We simulate our model using the actexist option in the exclude command. We would like to generate add-factors so that we can turn the actexist option off and the re-simulate the model and still get the identical path we had when the actexist option was activated. I thought these commands would do it
m.exclude(actexist=t)  {%exclude}
m.solve
m.exclude(actexist=f)  {%exclude}
m.addinit(v=a) @all
but, if I then solve the model again (m.solve) it does not reproduce the original path. How can I generate add-factors so that the model will reproduce the path when the actexist option was active?
t
EViews Matt
Re: actexist
Postby EViews Matt » Fri Aug 21, 2020 9:57 am
I'm also surprised that didn't work as expected. However, in this case I believe the (v=n) option to addinit is a workable substitute.
Re: actexist
Postby tvonbrasch » Fri Aug 21, 2020 10:46 pm
Thanks for your reply, Matt. It does not work with v=n. I am probably doing something wrong. Can you please take a look at the following code:
'set smpl
   smpl 2018 2025
'turn on actexist
   {%m}.exclude(actexist=t) {%excludes}
'solve model
   {%m}.solve
'copy solution
   copy *_kt *_kt2
'set residuals to match actives
   {%m}.addinit(v=a) @all  '(it does not work with v=n)
'turn off actexist
   {%m}.exclude(actexist=f) {%excludes}
'solve the model again
   {%m}.solve
'compare solutions
   smpl 2019:3  2020
   line ur_kt ur_kt2
This produces the following graph:
As you can see, the simulation does not reproduce the actuals-value in 2020:2.
Is there an obvious fix that I should do? If not, I can share the workfile with you on monday.
t
EViews Matt
Re: actexist
Postby EViews Matt » Sun Aug 23, 2020 12:36 pm
Hmm. Yes, please do share your workfile.
EViews Matt
Re: actexist
Postby EViews Matt » Tue Aug 25, 2020 5:49 pm
I believe the issue is a set of missing add factors for 10 variables named pcja??_a. Some series with that name pattern are add factors for variables named pcja??, but the 10 variables I speak of unfortunately are named like add factors and would have their own add factor series named pcja??_a_a. Simply reenabling add factors for all of the model's variable appears to fix the issue, e.g., inserting "{%m}.addassign @all" before the addinit statement.
Re: actexist
Postby tvonbrasch » Wed Aug 26, 2020 3:58 am
Thanks for looking into this, Matt. The model object did have add-factors, also for those equations, but they were labelled with the alias "_a2". I changed the add-factors based on the forum post: http://forums.eviews.com/viewtopic.php?f=10&t=20252. As you stated in that post, the proposed solution "doesn't appear to break anything, but no guarantees." I guess this example illustrates that EViews cannot handle that add-factors are given another alias than "_a" ? Or is there a way to overcome this that I have not thought of yet?
Thanks again Matt for looking into this
t
EViews Matt
Re: actexist
Postby EViews Matt » Wed Aug 26, 2020 4:27 pm
In the model you sent me, the last 10 equations did not have add factor enabled. The odd add factor names worked fine for me, e.g., variable pcja00's add factor is named pcja00_a2 because pcja00_a is another variable in the model. I think the root issue was just that 10 variables were missing add factors, e.g., pcja00_a didn't have an add factor (to be named pcja00_a_a), which turned out to be necessary to match the trajectory you wanted.
Re: actexist
Postby tvonbrasch » Thu Aug 27, 2020 9:11 am
ah, right, now I understand. Thanks Matt!
t
Return to “Models”
