Diebold-Yilmaz index
dakila
Re: Diebold-Yilmaz index
Postby dakila » Thu May 07, 2020 6:13 pm
No. it does not affect the results. If you want to label variables for the table results, use this option.
Ning
Postby Ning » Sat May 09, 2020 8:09 pm
Hello, when I choose "Generalized" to run the index I get an error that says "Dot, diagonal, and solve require a vector argument", but I can get result when I choose "Cholesky". I wonder what does that mean because I want to use generalized variance decomposition. Could you please help me?
Haoren
Postby Haoren » Mon Jul 06, 2020 10:15 am
Could anybody help me? How to calculate the directional spillovers, net spillovers and net pairwise spillovers? My endogeneous variables are sp500 r_10y djubscom usdx, number of lags is 4, generalized, and I choose Roll. I choose save pairwise spillovers. It says Error 14 in encrypted program. All of those ps are NA.
dy2012 (1).xlsx
(183.86 KiB) Downloaded 12 times
Stataman
Postby Stataman » Thu Jul 16, 2020 2:56 am
Hi, I am new in this forum.
I am working on my dissertation and I came across with this methodology (Diebold-Yilmaz index) that i found specially interesting.
Maybe it is a silly question but I would like to know if we must work with STATIONARY data (making for instance the 1º difference and testing unit roots) whenever we are going to build the index. Or the calculations for the spillovers work also for the raw data, and there is no need for transformation?
Many Thanks
Kind Regards
Stataman
Postby Stataman » Mon Jul 20, 2020 5:22 am
I am performing the Diebold-Yilmaz spillover index using the Add-In.
The results are consistent for the TOTAL spillover idex. However, the output does not generate the Net splillover index.
One could just substract the two matrix output (To matrix - From Matrix) to obtain the NET SPILLOVER, however when I open those matrix I realize that there are not dates inside, that complicates the interpretation.
Furthermore, the matrix output does not contain the names of the endogeous variables, and it assign new variables names.
I would really apreciate your help.
Many thanks
Kind Regards
dakila
Postby dakila » Mon Jul 20, 2020 6:02 pm
You are right. You already did it manually. That is only possible way to get the net spillover index. I will update it sometimes later.
Return to “Add-in Support”
