Threshold Structural VAR
dakila
Re: Threshold Structural VAR
Postby dakila » Mon Sep 17, 2018 7:52 am
Sorry, no.
Shwan
Postby Shwan » Sun Apr 28, 2019 10:16 am
Hi, is there any recent developed code to obtain confidence intervals for the thsvar impulse responses?
thanks for the add in, but its totally impossible to convince a reviewer to have positive comments about a paper that generates impulse responses without the confidence intervals, its like reporting regression results without inferences! How can we know its statistically significant!
dakila
Postby dakila » Sun Apr 28, 2019 8:45 pm
Unfortunately, no.
icamara
Postby icamara » Fri Jul 26, 2019 11:39 am
How can I see or display the GIRFs graph after estimating the thsvar. I checked in the workfile but couldn't see it.
Best
danielamartins97
Postby danielamartins97 » Wed Oct 30, 2019 6:20 am
Dear all,
Since the EViews Add-in regarding the generation of the GIRFs does not include the confidence bands, I would like to know if there is a programming code available to compute the GIRFs as well as the confidence bands. Nevertheless, if you know a code or other way to compute it using R or Matlab, please share.
Thank you so much.
refp
Postby refp » Mon Mar 09, 2020 2:49 am
Dear community,
While using the THSVAR in Eviews 11, I receive the following error ‘Error 33 in encrypted program’ and it cannot produce the impulse responses
The model I am trying to run contains the following endogenous variables: us_ltrate au_log_ngdp au_log_cpi au_strate au_log_neer
time period: 1993Q1 - 2019Q4
lags: 2
threshold variable: au_buscyc_ngdp
default for all the other settings...what am I doing wrong?
Many thanks in advance for your guidance! :P
datasetmain.wf1
(31.87 KiB) Downloaded 83 times
dakila
Postby dakila » Wed Mar 11, 2020 9:00 pm
you forget response variable. Also your threshold variable should be endogenous.
refp
Postby refp » Tue Apr 07, 2020 6:00 am
Thank you very much for your guidance Dakila, and sorry for my late response!
The add-in works fine now…but only for some countries in my workfile. For instance, when I run the thsvar with the following specification I get ‘Error 15’
-endogenous variables: au_growth_ngdp au_growth_cpi au_rate au_growth_neer au_buscyc
-time period: 1974m8-2019m9
-lags: 2
-threshold variable: au_buscyc
-response variable: au_growth_neer
-generalized impulse responses and default for all the other settings
…the very same 'Error 15' appears while using the log-version in the same time period and with the same threshold, any idea why? :)
Thanks again for your time and stay well!
dataset.wf1
(80.71 KiB) Downloaded 47 times
Return to “Add-in Support”
Users browsing this forum: No registered users and 10 guests
