EV11 crash when working with GeoMap
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 2:48 am
Dear guys,
I'm working with GeoMap and eviews 11 crashes every time I change some settings.
Re: EV11 crash when working with GeoMap
Postby EViews Gareth » Tue May 14, 2019 6:11 am
Would you mind providing some more details?
What settings are you changing?
Even better, could you provide the files?
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 8:53 am
Dear Gareth,
I simply downloaded a map of the USA taken from an American government website. Since I am interested in the contiguous US map (i.e., 48 states) I remove the two states that do not interest me from the main menu. I save the map on the Eviews file and as soon as I open it the software crashes. Similarly, if I try to save the map as an image ("freeze"), Eviews crashes.
Postby EViews Jason » Wed May 15, 2019 8:21 am
Can you post the link of the shapefile you are using or send me the file directly to jason@eviews.com? I will need the prj, shp, shx, dbf, and any other optional files.
What procedure are you using to remove the unwanted states?
Wiz_Ven
Postby Wiz_Ven » Wed May 15, 2019 9:00 am
Thank you for your reply. You find the map in the attached file. I have uploaded the GeoMap simply using "New Object" -> "GeoMap" and selecting the prj file. Then I have removed the unnecessary states unselecting from the visibility states option under "Appereance".
tl_2014_us_state.zip
(8.21 MiB) Downloaded 116 times
Postby EViews Jason » Thu May 16, 2019 11:07 am
We are unable to produce the reported behavior.
What is your EViews build date (select Help->About EViews)?
Is your copy up to date (select Help->EViews update)?
Wiz_Ven
Postby Wiz_Ven » Thu May 16, 2019 12:44 pm
My build date is May 15 2019. I have tried again but eviews crashes when you try to save the map pushing the button "freeze".
Postby EViews Gareth » Thu May 16, 2019 12:45 pm
Which states did you remove?
Postby EViews Gareth » Thu May 16, 2019 12:49 pm
It might be data related - would it be possible to email Jason the workfile into which you're importing the map, and stating which series you're matching the data to?
Wiz_Ven
Postby Wiz_Ven » Fri May 17, 2019 5:27 am
Thank you for your reply. Here you find the Eviews file. If you create a new US GeoMap at state-level and associate states with "av_num_torn" series you find in the WF1 file attached, eviews crashes. No matter which source you use to create the map, eviews always crashes. Eviews also crashes when you simply try to save the US map you just created (using "Freeze" command) without attaching any series.
us_states_torn.WF1
(14.02 KiB) Downloaded 85 times
Postby EViews Jason » Mon May 20, 2019 10:15 am
Thank you for the workfile. We found the problem. It will be fixed in the next patch.
ppicchetti
Postby ppicchetti » Fri Aug 09, 2019 7:34 am
I've just installed the Jul 30 2019 build, and it crashes every time I just try to create a GeoMap new object, even before trying to load any shapefile Running EViews 11 on Windows 7). Has anyone else experienced the same issue?
Postby EViews Gareth » Fri Aug 09, 2019 8:05 am
No other reports of that - weird. Could you email support@eviews.com so we can investigate further?
fmramos
Contact:
Postby fmramos » Fri Jan 24, 2020 6:28 am
Hi there! I'm having the same issue. I sent an email to support@eviews.com recently, but I don't now if they got the message. Whenever I try to use geomap tool, EV11 crashes. Tks, Fabio
fmramos
Contact:
Postby fmramos » Tue Jan 28, 2020 11:35 am
Probably it is something related to internet connection, proxy etc. At home it is working OK. At office, whenever I open the tool for geomap, EV11 crashes. :|
Users browsing this forum: No registered users and 24 guests
