Diebold-Yilmaz index
dakila
Re: Diebold-Yilmaz index
Postby dakila » Tue May 14, 2019 4:40 pm
What is your eviews version?
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 9:09 pm
Eviews 11.
dakila
Postby dakila » Tue May 14, 2019 11:30 pm
Yes, you are right. It does not work for the version 11. I will fix it soon. But it can work for the version 10 if you have access to it.
Wiz_Ven
Postby Wiz_Ven » Tue May 14, 2019 11:59 pm
I have also Ev 10+ and the same error appears.
dakila
Postby dakila » Thu May 16, 2019 6:15 pm
The bug is fixed. Please update the add-in. I hope the moderator will post it soon. But carefully choose the rolling window parameter. It should not exceed the sample size.
Wiz_Ven
Postby Wiz_Ven » Fri May 17, 2019 5:31 am
Thank you very much. As soon as the new version of the code is online I will try to run the code following your instructions.
Wiz_Ven
Postby Wiz_Ven » Fri May 17, 2019 10:03 am
Dear Dakila,
I have tried the updated version. Now it works fine. Thank you very much.
Asimshaikh
Postby Asimshaikh » Thu Jun 13, 2019 12:20 am
dakila wrote:This thread is about the dyindex add-in that estimates the Diebold-Yilmaz index of spillover using forecast error variance decomposition method of a VAR model.
I am new to this method can anybody help me by telling steps to calculate dyindex?
Return to “Add-in Support”
