Command explorer window
Postby startz » Wed Apr 10, 2019 2:38 pm
If one accidentally closes the command explorer, there doesn't appear to be a way to re-open it.
Re: Command explorer window
Postby EViews Jason » Wed Apr 10, 2019 4:09 pm
You currently have to restart EViews but we will add a menu item to the Windows menu.
Postby startz » Wed Apr 10, 2019 4:25 pm
Surely, you didn't expect me to report something you could fix so easily!
On my machine at home, closing and re-opening EViews restores the command explorer.
On my machine at work, closing and re-opening EViews DOES NOT restore the command explorer. But to keep things entertaining, if I reset the windows views to the default and then re-open the command explorer does appear--outside the EViews master window.
Done this twice on both machines.
(Both machines are up-to-date Windows 10 with lots of ram etc.)
Postby EViews Steve » Thu Apr 11, 2019 7:33 am
I would suppose our "Reset Window Layout" menu option under the Window menu should reset this Command Explorer window as well.
