LogMsg bug?
johansamuelsson
Contact:
LogMsg bug?
Postby johansamuelsson » Mon Apr 01, 2019 9:36 am
I have two files
c:\temp\p1.prg
LogMode(name="logg") LogMsg
LogMsg 11
Exec c:\temp\p2.prg
LogMsg 12
and c:\temp\p2.prg
LogMsg TEST
When running p1.prg Eviews ouput (in the log) is
11
12
I expected
11
TEST
12
Or am I wrong?
Regards Johan
EViews Katerina
Re: LogMsg bug?
Postby EViews Katerina » Mon Apr 01, 2019 11:34 am
If your p1 was :
LogMsg 11
include c:\temp\p2.prg
LogMsg 12
Then the output in the log window would be:
11
TEST
12
The exec command executes another program. The include statement includes the contents of another file in a program file.
Using the exec command you need to add logmode to your second program ;
logmode l
LogMsg TEST
then a second log would open and display
TEST
johansamuelsson
Contact:
Re: LogMsg bug?
Postby johansamuelsson » Tue Apr 02, 2019 11:20 am
Ok, thanks
Regards Johan
linkan
Re: LogMsg bug?
Postby linkan » Wed Apr 03, 2019 5:47 am
The prg-files Johan showed worked up until the most recent patch, in witch this behaviour was removed. Is there a reason that it is removed?
EViews Katerina
Re: LogMsg bug?
Postby EViews Katerina » Thu Apr 04, 2019 1:02 pm
We have an internal discussion about the issue. We will update you once is resolved.
EViews Katerina
Re: LogMsg bug?
Postby EViews Katerina » Tue Apr 16, 2019 2:31 pm
With the latest patch we reverted to previous behavior of EViews10 for logging program messages when exec command is used inside a program:
p1.prg :
LogMode l
LogMsg 11
exec p2.prg
LogMsg 12
p2.prg:
LogMsg TEST
11
TEST
12
EViews11 behavior is changed and the program that is being executed with exec command will require a LogMode command and log messages will be displayed in a new dialog as described in previous post.
linkan
Re: LogMsg bug?
Postby linkan » Wed Apr 17, 2019 12:32 am
EViews Katerina wrote:EViews11 behavior is changed and the program that is being executed with exec command will require a LogMode command and log messages will be displayed in a new dialog as described in previous post.
Why is this change implemented in Eviews 11? It feels strictly worse than the Eviews 10 behaviour. At least it should be possible to get the old behaviour with a Logmode option.
Re: LogMsg bug?
Postby tvonbrasch » Tue Aug 04, 2020 12:14 pm
Have you done anything with this logmsg-issue?
t
Users browsing this forum: No registered users and 3 guests
