Formatted Multiple Equation Output Table
This program takes the output from the equations in your workfile and formats them into a single table.
Note this program requires EViews 7 or above!
- single dependent grid.prg
- (10.34 KiB) Downloaded 1834 times
Re: Formatted Multiple Equation Output Table
Very nice !!!
Nice program! Very Helpful.
I will get a lot of use out of it. Thanks for posting. Very helpful for us novice programmers to learn from your work.
Is there any way to get it to also give the results for the variance equation in a Garch model?
Other suggested modifications:
options for adding AIC, SIC, Durbin Watson,
Also maybe put estimation type, sample range, and estimation options (Newey/West, White, Bollerslev/Wooldridge) in bottom left corner)
I believe it does give equation method, as an option.
The others should be fairly easy for you to add yourself - it was posted as an example of EViews programming after all! If you have a go and get stuck, I'm sure I can help out.
I have UK date format and the code does not like that. Is there a way that I can deal with that without changing my default options? I cannot see anything obvious in the code.
I can't think of any reason why your date format will affect the program. Could you be more specific than "the code does not like that"?
You're right - I'm sorry.
QMS Gareth wrote:I believe it does give equation method, as an option.
I think I can add the other indicators but I can't figure out how to get the GARCH variance equation output to be in the output table. Any advice??
JF
Well the values you're after are stored in the same place - i.e. the coefficients from the variance equation are stored in @coefs, in the same way the coefficients from the mean equation are. The problem is that the names of the coefficients, which are in %allregs, and are being pulled from the @varlist data member of an equation aren't getting stored, since the @varlist member does not include the variance terms.
I can't think of a general way around that issue. I'll give some thought to adding a new data member that contains the names of the variance equation terms for an update to EViews.
QMS Gareth,
This is a great code. I'm new to programming eViews, but have done much other programming before. I'm currently using eViews 6 instead of 7 -- what pieces of this code depend on functionality specific to version 7? Does it seem reasonable to try to implement this same process in version 6?
Any tips you provide as a place to start would be much appreciated!
Too much of the code requires the new data members, and workfile lookup functions available in EViews 7. The code would not be possible in EViews 6.
I have downloaded, I want to thank you for the great effort
I have looked the details, what can I say, unbelievable hard to write
cheers
cheers
I will get a lot of use out of it. Thanks for posting. Very helpful for us novice programmers to learn from your work.forest City HS Class of 1975
Dear, the .prg is not available anymore. Could you see into it? Or possibly provide a link to similar program which creates an output table. This is such a trivial thing, yet very helpful and somehow ignored here on the Forum. Thanks and best wishes!
Download the EqTabs add-in instead. http://www.eviews.com/Addins/addins.shtml It has the same code, but packaged as an add-in. You can always look at the source code, if you want to modify it.
Return to “Program Repository”
