Variables as parameters in SQL procedure call
lgazire
Postby lgazire » Thu Feb 21, 2019 10:26 am
I want to execute the following case?
   %s = @str(!productId)
   pageload(page={%produto}, type=odbc)  "Description=DEsc;DRIVER=ODBC Driver 13 for SQL Server;SERVER=localhost;Trusted_Connection=Yes;APP=EViews;DATABASE=Db;" "{call USP_SEL_GetMovingAveragePriceQuote ("+%s+"))}"
But i got the error:
 ODBC Error 42000: Syntax error, permission violation, or
 other nonspecific error in "PAGELOAD(PAGE=RICE,
 TYPE=ODBC)  "DESCRIPTION=DESC;DRIVER=ODBC
 DRIVER 13 FOR SQL SERVER;SERVER=LOCALHOST;TRUSTED
_CONNECTION=YES;APP=EVIEWS;DATABASE=DB;" "{CALL USP_SEL_GETMOVINGAVERAGEPRICEQUOTE ("+"1"+"))}"".
If i pass directly it doesn´t show any errors, what am i doing wrong?
Re: Variables as parameters in SQL procedure call
Postby EViews Gareth » Thu Feb 21, 2019 10:37 am
Looks like you have two close parens at the end, but only one open paren.
Also, it might be safer to build up that second string as a variable and use that:
%s = "{call USP_SEL_GetMovingAveragePriceQuote ("+@str(!productID)+")}"
pageload(page={%produto}, type=odbc)  "Description=DEsc;DRIVER=ODBC Driver 13 for SQL Server;SERVER=localhost;Trusted_Connection=Yes;APP=EViews;DATABASE=Db;" %s
Postby EViews Gareth » Thu Feb 21, 2019 10:45 am
Users browsing this forum: Baidu [Spider] and 18 guests
