@active
@active
Postby tvonbrasch » Sun Feb 10, 2019 11:45 pm
the option @active to specify the active scenario needs different handling when used in a program and in the command field, e.g.
model.@varlist(@active)
works in the command field, but
model.@varlist("@active")
(with quotes) must be used in a program. Should it not be the same code both in a program and in the command field?
