Large Bayesian VAR
Re: Large Bayesian VAR
You should upgrade the eviews to version 10.
Hi Dakila,
thank you for reply.
As you suggested I upgraded to Eviews 10.
However it returns me the message: Error 14 in the encrypted program.
Could you please guide me?
Thank you for your time
Could you be more specific?
Can you run the example file, for example lbvar_ex0.prg?
Hi Dakila, I am currently using the feature and it works very well. I was just wondering however, whether there is a way to run RMSE or MAE tests for the estimated LBVAR and whether it is possible to specify another structural estimation besides Cholesky and Generalised.
Thank you in advance
i have this error message when i compute lbvar
MIXED is not a valid view for TEMP
how can i solve it ?
THANKS
THANKS
What is the version of Eviews you use?
hi
eviews9. I I just tried it with eviews10, the problem is solved.
thanks
thanks
The LBVAR add-in is updated. Now it includes Pandemics Prior of Cascaldi-Garcia (2022). I would like thank Dr. Ole Rummel (SEACEN centre) for suggestions and comments on Pandemic Priors.
Hi, is there a command to get the output lbvar specification so we know the coefficient?
No. I will try to include this option to get the coefficients soon.
thank you, it would be wonderful
Sorry, I forget. I already included the option to save the coefficients. Command is save=1.
For example:
The coefficients are saved into beta_coef matrix.
For example:
lbvar(lambda=0.108, tau=1.08, sample="1961m1 2002m12", save=1) 13 irw ffr @ emp cpi .... exr
thank you
another question, does pand=1 option works with quarterly data? I try, but it throws internal error 6, 169 and 500
It should work with quaterly data. Could you provide the data and instruction?
the first five commands work just fine
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" ) 4 irw10 lcsgnl @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" ) 4 irw10 lingnl @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" ) 4 irw10 lspen @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" ) 4 irw10 lrev @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" ) 4 irw10 ltax @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
the last one is not:
lbvar(estimate=1, sample="2000q1 2023q1", lambda=0.4, tau = 4, save=1, fit=" lcpipi lgdprl lexrpl", tsample="2000q1 2021q4" , pand=1, dummy="dum1 dum2 dum3 dum4 dum5 dum6 dum7 dum8", covper=8, eps=0.001 ) 4 irw10 ltax @ lspen polrate surpdef lingnl lcsgnl lrev ltax lcpipi lgdprl lexrpl
thank you very much for your help
kind regards,
ginanjar
kind regards,
ginanjar
- fiscal_bvar.wf1
- (353.96 KiB) Downloaded 93 times
Users browsing this forum: No registered users and 52 guests
