File IO Failed
dhityayl
File IO Failed
Postby dhityayl » Fri Oct 05, 2018 3:55 am
I have a code for loop programming below. So basically i loop a rolling regression and after that i want to save to excel.
The code below works for the looping itself (without wfsave), but in the middle of the looping with wfsave, the loop failed. The error message is : File IO failed for file 'Could not create entry in zip file.' in "WFSAVE(TYPE=EXCELXML) "C:\USERS\DHITYA\DESKTOP\2\2001.T.CSV.XLSX" @KEEP DATE RETURN G1".
Is there something wrong with the code? It works before with just 2 files, but when i do 50 files, it failed.
If i want to try running the program again with different data, i should create a new destination folder to save my file, but it will failed again in the middle of the loop.
Thankyou
cd "D:\Thesis_Loop\2002_2\dataset"
%filenames = @wdir("D:\Thesis_Loop\2002_2\dataset")
for !k=1 to @wcount(%filenames)
   %file = @word(%filenames, !k)
   wfopen %file
   import D:\Thesis_Loop\2002_2\dataset\index\Indeks_2002.csv
   import D:\Thesis_Loop\2002_2\dataset\index\FF3_2002.csv
   genr return=(((close-close(-1))/close(-1))*100)-rf
!window = 60
   !step = 1
   !length = @obsrange
   equation eq1
   !nrolls = @round((!length-!window+1)/!step)
   matrix(5,!nrolls) coefmat!k
   !j=0
      for !i = 1 to !length-!window+1-!step step !step
      !j=!j+1
      smpl @first+!i-1 @first+!i+!window-2
      equation eq1.ls return c indeks mkt_rf smb hml
      colplace(coefmat!k, eq1.@coefs,!j)
      matrix(!nrolls,5) r1
      matrix r1=@transpose (coefmat!k)
         series rbc
         series rbindeks
         series rbmkt
         series rbsmb
         series rbhml
         group g1 rbc rbindeks rbmkt rbsmb rbhml
         sample s1 @first+59 @last
         mtos(r1, g1, s1)
            if @isobject("s1") then
            delete s1
            endif
%path = "C:\Users\Dhitya\Desktop\2\" + %file + ".xlsx"
wfsave(type=excelxml) %path @keep date return g1
   'close @all
Re: File IO Failed
Postby EViews Jason » Fri Oct 05, 2018 8:57 am
Is it failing on the same file every time (i.e. does the error message always refer to C:\USERS\DHITYA\DESKTOP\2\2001.T.CSV.XLSX)?
Can you post the list of filenames in the C:\USERS\DHITYA\DESKTOP\2 directory?
dhityayl
Re: File IO Failed
Postby dhityayl » Fri Oct 05, 2018 3:27 pm
Hi. It works fine on other computer. I think the problem is not on the eviews program.
Thank you
Re: File IO Failed
Postby EViews Jason » Wed Oct 10, 2018 7:21 am
I would then verify all the paths and files that are being referred to in your program exist. For example, make sure C:\USERS\DHITYA\DESKTOP\2\ and D:\Thesis_Loop\2002_2\dataset\index\ exist.
