I execute the following command line six times (in a loop).
{%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
Summation works only for the first 5 steps, but not the sixth. When I subsequently compute an additional series as
series ztestsumm = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
summation suddenly works. Is there an obvious reason for this behavior?
many thanks
one step in loop summation not executed
Re: one step in loop summation not executed
Not sure whether this can help: i included the entire monsterloop, in which the command line is embedded, and highlighted the command line I sent earlier in red. Again in essence: the loop would add six times new information for the replacement series {%replacename2_2}, which is originally declared and set to series containing exclusively zeros, but it does so only five times. Once I construct a new series doing the addition one time more the result is correct => the last step of the loop is not executed!
for %indicator {indicatoracroloop}
sectoracro = @wnotin(@wnotin(sectoracro, %sectoracroaggexc),"SECAGG OFI OFI2 OFINCLB OFINCLN")
%varname1 = "ind_1_" + %indicator + "_*"
%varname2 = "ind_2_" + %indicator + "_*"
%varname4 = "ind_4_" + %indicator + "_*"
%varname5 = "ind_5_" + %indicator + "_*"
%objectlist1 = @wlookup(%varname1)
%objectlist2= @wlookup(%varname2)
%objectlist4= @wlookup(%varname4)
%objectlist5= @wlookup(%varname5)
!objectnum = @wcount(%objectlist1)
for !z = 1 to !objectnum
%replacename1 =@wdelim(@wleft(@wdelim(@word(%objectlist1,!z),"_"," "),6)," ","_")
%replacename1a =@word(%objectlist1,!z)
%replacename2 = @wmid(@wdelim(%replacename1,"_"," "),4)
%replacename2 = "nfp " + %replacename2
%replacename2 = @wdelim(%replacename2 ," ","_") + "*"
!namenum=@wcount(%replacename2)
if !namenum > 1 then
%replacename3 = @wright(@wlookup(%replacename2),1)
else
%replacename3 = @wright(@wlookup(%replacename2),!namenum)
endif
%indfreq = @lower(@wright(@wdelim(%replacename1,"_"," "),1))
for %country {countryacro}
%exclname = @lower(%indicator)+ "_" + @lower(%country) + "_string"
%country1 = "_" + %country + "_"
if @isobject(%exclname)=1 then 'and {%exclname}.@type= "String"
string sectoracroloc = @wnotin(sectoracro,%exclname)
if @instr(%replacename1, %country1) > 0 and @instr(%replacename3, %country1) > 0 then
for %sector {sectoracroloc}
%sector1 = "_" + %sector + "_"
if @instr(%replacename1, %sector1) > 0 and @instr(%replacename3, %sector1) > 0 then 'or @isobject(%replacename3) )= 1
%existtestname = "denominator_" + %country + "_" + %indfreq
if @isobject(%existtestname) = 0 then 'series creation
series denominator_{%country}_{%indfreq} = 0
endif
denominator_{%country}_{%indfreq} = denominator_{%country}_{%indfreq} + @recode(@isna({%replacename3})=1,0, {%replacename3}) ' @recode({%replacename3}<>0, {%replacename3},NA) 'eliminate 0 entries in NFP series
endif
endif
delete sectoracroloc
else
for %sector {sectoracro}
endif
endif
endif
endif
else
endif
%replacename2 =@wdelim(@wleft(@wdelim(@word(%objectlist2,!z),"_"," "),6)," ","_")
%replacename2a =@word(%objectlist2,!z)
%replacename4 =@wdelim(@wleft(@wdelim(@word(%objectlist4,!z),"_"," "),6)," ","_")
%replacename4a =@word(%objectlist4,!z)
%replacename5 =@wdelim(@wleft(@wdelim(@word(%objectlist5,!z),"_"," "),6)," ","_")
%replacename5a =@word(%objectlist5,!z)
%exclname = @lower(%indicator) + "_" + @lower(%country) + "_string"
string sectoracroloc = @wnotin(sectoracro, %exclname)
if @instr(%replacename1, %sector1) > 0 and @instr(%replacename3, %sector1) > 0 and @instr(%replacename1a, %country1) > 0 then 'or @isobject(%replacename3) )= 1
%existtestname = @wdelim(@wleft(@wdelim(@replace(%replacename1,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename1_1 = @wdelim(@wleft(@wdelim(@replace(%replacename1,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename2_1 = @wdelim(@wleft(@wdelim(@replace(%replacename2,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename4_1 = @wdelim(@wleft(@wdelim(@replace(%replacename4,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename5_1 = @wdelim(@wleft(@wdelim(@replace(%replacename5,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
series {%replacename1_1} =0
series {%replacename2_1} =0
series {%replacename4_1} =0
series {%replacename5_1} =0
else
endif
series weight_{%indicator}_{%sector}_{%country}_{%indfreq} ={%replacename3}/@recode(denominator_{%country}_{%indfreq}<>0, denominator_{%country}_{%indfreq},NA)
{%replacename1_1} = {%replacename1_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename1a})=1,0, {%replacename1a})
{%replacename2_1} = {%replacename2_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename2a})=1,0, {%replacename2a})
{%replacename4_1} = {%replacename4_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename4a})=1,0, {%replacename4a})
{%replacename5_1} = {%replacename5_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename5a})=1,0, {%replacename5a})
endif
endif
else
series {%replacename1_1} = 0
series {%replacename2_1} = 0
series {%replacename4_1} = 0
series {%replacename5_1} = 0
else
endif
{%replacename4_1} = {%replacename4_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename4a})=1,0, {%replacename4a})
{%replacename5_1} = {%replacename5_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename5a})=1,0, {%replacename5a})
endif
endif
endif
delete denominator*
'''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' aggregation across countries
sectoracro = @wunion(sectoracro,"SECAGG OFI OFI2 OFINCLB OFINCLN")
countryacro = @wnotin(countryacro,"GL countryagg")
if %indicator = "LEV2" then
string zzztest = @wlookup("ind_2_lev2_*")
endif
if @instr(%replacename1, %sector1) > 0 then
if @instr(%replacename1, %country1) > 0 then
%existtestname = "denominatorcorr_" + %sector
series denominatorcorr_{%sector} = 0
endif
%namecheckEU = @replace(%replacename1,@upper(%country1),"_EU_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_EU",1),"_"," "),3) + "*"
%namecheckEA = @replace(%replacename1,@upper(%country1),"_EA_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_EA",1),"_"," "),3) + "*"
%namecheckNA = @replace(%replacename1,@upper(%country1),"_NA_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_NA",1),"_"," "),3) + "*"
%namecheckEU = @wkeep(%objectlist1,@upper(%namecheckEU))
%namecheckEA = @wkeep(%objectlist1,@upper(%namecheckEA))
%namecheckNA = @wkeep(%objectlist1,@upper(%namecheckNA))
if @wcount(%namecheckNA)=0 then
if @wcount(%namecheckEU)=0 then
if @wcount(%namecheckEA)=0 then
%regionreplace = "nat"
!prestest = @wfindnc("EU EA NA",%country) ' to be updated if country coverage changes
if !prestest = 0 then
denominatorcorr_{%sector} = denominatorcorr_{%sector} + @recode(@isna( gdpdata\weights_{%regionreplace}_{%country})=1,0, gdpdata\weights_{%regionreplace}_{%country}) 'series value update
else
endif
else
%regionreplace = "EA"
!prestest = @wfindnc("AT BE DE EU FI FR IE IT LUX NL NA",%country) ' to be updated if country coverage changes
else
endif
endif
else
%regionreplace = "EU"
!prestest = @wfindnc("AT BE DE EA FI FR IE IT LUX NL UK PL NA",%country) ' to be updated if country coverage changes
denominatorcorr_{%sector} = denominatorcorr_{%sector} +@recode(@isna( gdpdata\weights_{%regionreplace}_{%country})=1,0, gdpdata\weights_{%regionreplace}_{%country}) 'series value update
else
endif
else
%regionreplace = "EUEA"
!prestest = @wfindnc("AT BE DE FI FR IE IT LUX NL UK PL NA",%country) ' to be updated if country coverage changes
else
endif
if %comparetemp = "IND_2_LEV2_SECAGG" then
series ztestdenom = denominatorcorr_{%sector}
endif
endif
endif
else
if @wcount(%namecheckEU) =0 then
if %namecheckEA =0 then
%regionreplace = "NA"
!prestest = @wfindnc("US CA EU EA",%country) ' to be updated if country coverage changes
else
endif
else
%regionreplace = "EANA"
!prestest = @wfindnc("US CA AT BE DE EU FI FR IE IT LUX NL",%country) ' to be updated if country coverage changes
else
endif
endif
else
if @wcount(%namecheckEA) =0 then
%regionreplace = "EUNA"
!prestest = @wfindnc("US CA AT BE DE FI FR IE IT LUX NL UK PL EA",%country) ' to be updated if country coverage changes
else
endif
else
%regionreplace = "EUEANA"
!prestest = @wfindnc("US CA AT BE DE FI FR IE IT LUX NL UK PL",%country) ' to be updated if country coverage changes
else
endif
endif
endif
endif
endif
endif
%existtestname = @wdelim(@wleft(@wdelim(@replace(%replacename1,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename1_2 = @wdelim(@wleft(@wdelim(@replace(%replacename1,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename2_2 = @wdelim(@wleft(@wdelim(@replace(%replacename2,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename4_2 = @wdelim(@wleft(@wdelim(@replace(%replacename4,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename5_2 = @wdelim(@wleft(@wdelim(@replace(%replacename5,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
series {%replacename1_2} =0
series {%replacename2_2} =0
series {%replacename4_2} =0
series {%replacename5_2} =0
endif
%comparetemp= @upper(@wdelim(@wleft(@wdelim(%replacename2,"_"," "),5)," ","_"))
if %comparetemp = "IND_2_LEV2_SECAGG_US" then
string zstring = %namecheckEU
string zstring1 = %namecheckEA
string zstring2 = %namecheckNA
endif
if @wcount(%namecheckNA) =0 then
series weight_{%indicator}_{%country}_{%sector} =gdpdata\weights_{%regionreplace}_{%country}/@recode(denominatorcorr_{%sector}<>0, denominatorcorr_{%sector},NA)
{%replacename1_2} = {%replacename1_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename1a})=1,0, {%replacename1a}) 'series value update
{%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename4a})=1,0, {%replacename4a})
{%replacename5_2} = {%replacename5_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename5a})=1,0, {%replacename5a})
else
endif
else
!prestest = @wfindnc("AT BE DE EU FI FR IE IT LU NL NA",%country) ' to be updated if country coverage changes
{%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode (@isna({%replacename4a})=1,0, {%replacename4a})
else
endif
endif
else
!prestest = @wfindnc("AT BE DE EA FI FR IE IT LU NL UK PL NA",%country) ' to be updated if country coverage changes
series weight_{%indicator}_{%country}_{%sector} = gdpdata\weights_{%regionreplace}_{%country}/@recode(denominatorcorr_{%sector}<>0, denominatorcorr_{%sector},NA)
else
endif
else
series {%replacename1_2} = {%replacename1_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename1a})=1,0, {%replacename1a}) 'series value update
series {%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
series {%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename4a})=1,0, {%replacename4a})
series {%replacename5_2} = {%replacename5_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename5a})=1,0, {%replacename5a})
' if %comparetemp = "IND_2_LEV2_SECAGG_US" then
' zscalar = zscalar +1
' {%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
' series ztestsumm = {%replacename2_2} '+ @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
' scalar zscalar2 = !prestest
' string ztestword = %country
' endif
else
endif
endif
endif
else
else
endif
else
else
endif
endif
else
else
endif
else
else
endif
endif
endif
endif
endif
endif
delete denominator_corr*
countryacro = @wunion(countryacro, "GL COUNTRYAGG")
else
endif
endif
endif
endif
else
endif
endif
endif
endif
else
endif
else
endif
endif
endif
else
else
endif
endif
endif
endif
delete denominator*
endif
endif
else
endif
else
else
endif
endif
else
else
endif
else
else
endif
endif
endif
endif
else
else
endif
else
else
endif
endif
else
else
endif
else
else
endif
endif
endif
endif
endif
endif
endif
endif
else
endif
else
else
endif
endif
else
else
endif
else
' endif
else
endif
endif
endif
else
else
endif
else
else
endif
endif
else
else
endif
else
else
endif
endif
endif
endif
endif
endif
Yeah, that's a bit much to debug by site. You're going to have to debug manually.
I cases like this I like to create a table object outside of the loop, then record all the variables inside the loop so that I can see what is going on.
Something like:
Something like:
table temp
temp(1,1) = "!a"
temp(1,2) = "%j"
temp(1,3) = "!i"
!r=2
for %j {%mylist}
for !i= 1 to 10
'stuff here involving %j, !i and another variable !a
temp(!r,1) = !a
temp(!r,2) = %j
temp(!r,3) = !i
!r=!r+1
Debugging gives me the strange results that I have after the sixth adding operation a nonzero value in the series %replacename2_2 when reporting it to a table, but a zero value in the graph of the actual series. i guess the variable does not date up the latest loop step? What can i do?
Users browsing this forum: No registered users and 44 guests
