command history in series
Dear forum, I manipulate some series several time in sequence. However, when I open the spreadsheet of the transformed series, I can only see the last three transformations in the label rows.Wwould it be possible to change the settings, so that I can see all transformation conducted? many thanks
Re: command history in series
I think the history is set to the last 6 changes, and that is hard coded - no way to change it.
Are you sure about the number 6 for the transformations documented? Or could it be that the number of rows available for reporting transformations is set to 6 implying that potentially only 3 transformations are reported? Despite conducting quite a lot of transformations, I find in each series only the last three reported.
There is a limit of six lines of history information following the topmost "Last updated" entry. However, lengthy update expressions span two lines. In practice, you'll see between the last three to six changes made, but no more than six lines total.
Users browsing this forum: Google [Bot] and 17 guests
