I found that datenext is not working properly using monthly data. For example, while the first command below gives the correct result on my comupter, the command below does not. I was able to reproduce this on other computers as well:
show @datenext(@dateval("1995M01"), "mm")
show @datenext(@dateval("2000M03"), "MM")
Regards
datenext bug
Re: datenext bug
What result did it give you that was incorrect?
I just ran it on my PC and it gave the correct date (2000/04/01)
Re: datenext bug
It seems to only be an issue with M3, M6, M9 and M12
M3 gives me 2000Q2, M6 200S2 M9 2000Q4 and M12 2001
Re: datenext bug
Oops using EViews 10 Enterprise March 15 2018 build
Re: datenext bug
Note that the function will return a date. As in a single day.
2000Q2 is the same thing as 2000M6, which is the same thing as 2000/06/01.
If you would like the result shown in a different date format, change the display format in which you are displaying the date.
Users browsing this forum: No registered users and 16 guests
