Changing variable names in several equations
I changed the text string part of the name of a batch of series. For example, they were named XX1000... and now they are named YY1000... There is one equation per each series (For forecasting). Is there a way to write a program in order to modify the name of the series in the equations instead of having to manually change them one by one?
Thank you in advance to anyone who can help me with this!
Re: Changing variable names in several equations
Use @wlookup to get a list of all equations in your workfile. Loop through those equations one by one.
For each equation use eqname.@command to retrieve its estimation command. Then use @wreplace to replace the variables in the estimation command, then issue the command to re-estimate the equation.
Hi Gareth,
Thank you for replying! I have something like this from one of the threads on programming, but the replace part I am not sure where/how to place it
Thank you again for your help.
%eqlist=@wlookup("*","equation") 'make a list of all equations in workfile
for !i=1 to @wcount(%eqlist) 'cycle through the list one at a time
%eq = @word(%eqlist,!i) 'current equation name
%estcmd = {%eq}.@command 'current equation's specification command
@wreplace XX* YY* ' not sure about how to do this step
{%eq}.{%estcmd} 're-estimate current equation with its command
%estcmd = @replace(%estcmd, "YY", "XX")
{%eq}.{%estcmd}
Hi Gareth,
It gives me an error:
XX10000...is not defined in "DO_EQ_YY10000.LS (OPTMETHOD=OPG) XX10000 @EXPAND(@MONTH) @EVENT("2016M09") AR(1)"
I changed the code slightly to:
Now it makes the conversion but now an error says "insufficient number of observations" when it tries to estimate each equation
%estcmd = @wreplace(%estcmd, "*XX*" , "*YY*")
Do you have enough observations?
Yes, I re-estimate these equations periodically and the sample is large enough. The only change is the name of the variables.
I finally was able to figure out the problem. The last time I outputted the forecasts I did it defining the sample to output and that was causing the sample in the workfile to be defined as the forecast sample.
Thank you Gareth for all your help. It is really satisfactory to be able to accomplish a massive task with some lines of code.
Hi Gareth,
How can I keep each equation sample estimation when estimating several equations at once?
When I run this program, it estimates each equation with all the data that each series has instead of estimating each equation with its own estimation sample.
Thank you in advance for your help
%estcmd = {%eq}.@command 'current equation's estimation command
Retrieve the equation's sample using eq.@smpl, then set the workfile sample to that sample, then re-estimate.
%eqsmpl = eq.@smpl
smpl {%eqsmpl}
'estimate
It worked! Thank you!
Hi Gareth,
In the same line, how can I forecast from all the equations and store the forecasts (defining a forecast sample as fore? For example, For each series in the equation, store the forecast in a new series adding _f to the name. I don't know how to retrieve the name of the series in each equation.
So far I have this
So far I have this
smpl fore
{%eq}.forecast {%series}_f 'I don't know how to retrieve %series
series {%series}_f
Use equation.@varlist and @word
Users browsing this forum: No registered users and 43 guests
