Programming a table
miorinnovo
Programming a table
Postby miorinnovo » Fri Jan 12, 2018 8:03 pm
How can I program a table so that the data will update with the chosen sample length.
Right now in my table I have @mean(variable). the mean of that variable does not change even if I change the length of my sample. How can I have the table react to sample length?
Re: Programming a table
Postby EViews Gareth » Fri Jan 12, 2018 8:03 pm
You cannot.
miorinnovo
Postby miorinnovo » Fri Jan 12, 2018 8:15 pm
Ok thanks. I guess i just have to rerun the table each time.
miorinnovo
Postby miorinnovo » Sat Jan 13, 2018 3:37 pm
IS there a way to give data for different samples? For example variable a's mean from 2010-2012 but variable b's mean from 2010-2015?
thanks
Postby EViews Gareth » Sat Jan 13, 2018 4:59 pm
What do you mean by "give"?
miorinnovo
Postby miorinnovo » Tue Jan 16, 2018 7:22 am
I meant display, but i found a work around...
Actually on another point, I'm using the (cov=hac) version of a univariate least squares regression. Is there a way to display the resulting p value in a tables?
Postby EViews Gareth » Tue Jan 16, 2018 9:01 am
Which p-value?
miorinnovo
Postby miorinnovo » Tue Jan 16, 2018 9:17 am
The p value for the constant and/or and other variable in the regression.
Postby EViews Gareth » Tue Jan 16, 2018 9:38 am
miorinnovo
Postby miorinnovo » Wed Jan 24, 2018 9:31 am
Thanks.
As a follow up, can you tell em how to get the p-value for the Breusch-Godfrey Serial Correlation LM Test in a table?
Using
equation.@pval(1)
gives me the pvalue for the first variable in that equation. How do I adjust this line of code to get the p-value from the f-test form the Breusch-Godfrey?
Thanks a lot.
Postby EViews Gareth » Wed Jan 24, 2018 9:34 am
miorinnovo
Postby miorinnovo » Thu Feb 01, 2018 1:24 pm
Thanks again. I'm using the code from this linked post:
freeze(tab1) eq01.wald c(1)=0
scalar f_pvalue = @val(tab1(6,4))
and this may be a dumb question but why does the p value for the f-stat that shows up in the "freeze" table not exactly the same as the Prob(Wald F-statistic) that gets reported in the estimation output for the same equaiton?
Thanks again
Postby EViews Gareth » Thu Feb 01, 2018 1:44 pm
Do you have more than one coefficient?
miorinnovo
Postby miorinnovo » Thu Feb 01, 2018 1:49 pm
I do but I made this adjustment to the code c(1)=c(2)=0.
Postby EViews Gareth » Thu Feb 01, 2018 2:38 pm
The report F-stat is the test that all the coefficients other than the constant are zero.
Users browsing this forum: Google [Bot] and 13 guests
