Switching regression Problem
Re: Switching regression Problem
Because you don't have a clear understanding of how the estimation works, what the options for estimation are, or how to read the output given by the estimation.
We always recommend users only use features for which they have a good understanding of the underlying theories and/or have read and understood the manual.
ok, so you're telling me that: even if I always use the same dataset in sample, is it normal for the model to return a different in sample result every time?
If you use random starting values, and your estimation doesn't converge, yes. By definition.
Because does the model, by construction, use random data regardless of the in sample dataset?
No, you told it to use random starting values.
Excuse me, what do you mean by random starting values?
If I estimate a model and save the equation at this point I can load new dates and use the equation with the guarantee that the coefficients are always the same? So always getting the same result in sample?
If not, how can I set the same starting values for an estimate?
from this window
https://ibb.co/eb8p46
from this window
nicotrader wrote:If I estimate a model and save the equation at this point I can load new dates and use the equation with the guarantee that the coefficients are always the same? So always getting the same result in sample?
Correct.
nicotrader wrote:If not, how can I set the same starting values for an estimate?
from this window
Use the same seed to ensure you get the same random numbers.
EViews Gareth wrote:nicotrader wrote:If I estimate a model and save the equation at this point I can load new dates and use the equation with the guarantee that the coefficients are always the same? So always getting the same result in sample?
Correct.
how can I save the model and consequently the equation and the coefficients?
If you haven't named the equation, hit the Name button.
Users browsing this forum: No registered users and 47 guests
