Switching regression Problem
nicotrader
Postby nicotrader » Thu Jan 04, 2018 1:02 pm
Hi all,
i have a problem with eviews 10 in particular with switch regression.
Then if I estimate a model and specific a sample, ex. 1-10000 observation of 12000 dataset the model rejects an output of probability state (STATIC FORECAST).
But if I estimate a model with same sample (1-10000 observation) but with 12500 dataset the model rejects a different output of probability state (STATIC FORECAST), then is impossible to estimate a reliable model.
If I add an observation in out-of sample the output in-sample result change!
please help.
Re: Switching regression Problem
Postby startz » Thu Jan 04, 2018 1:18 pm
May simply be a coincidence. Check that the starting values are the same for both estimates
nicotrader
Postby nicotrader » Thu Jan 04, 2018 6:09 pm
values ​​change I have tried innumerable estimate. ...
nicotrader
Postby nicotrader » Fri Jan 05, 2018 12:13 am
I have just made a further series of estimates, the problem exists.
Surely there is a bug problem, TO SOLVE URGENTLY.
Postby EViews Gareth » Fri Jan 05, 2018 3:56 am
Could you provide an example?
nicotrader
Postby nicotrader » Fri Jan 05, 2018 11:14 pm
I add an update.
The model output also changes when I use the same estimation model.
Incredible bug....
Model
https://ibb.co/bQuf6b
output
https://ibb.co/jV09zw
output
https://ibb.co/ds0WCG
Postby EViews Gareth » Sat Jan 06, 2018 12:06 am
I tried to recreate what I think you are explaining, but every thing looked ok...
create u 12262
series y=nrnd
smpl 1 10361
equation eq1.switchreg(type=markov, nstates=3) y c
smpl @all
eq1.fit yf
pagestruct(end=13000)
eq1.fit yf2
show yf yf2
nicotrader
Postby nicotrader » Sat Jan 06, 2018 8:23 am
I tried many times error is present, in addition you do not have the time series I use.
Postby EViews Gareth » Sat Jan 06, 2018 9:28 am
nicotrader wrote: in addition you do not have the time series I use.
Would it be possible to rectify that?
nicotrader
Postby nicotrader » Sat Jan 06, 2018 10:45 am
sorry, rectification what?
Postby EViews Gareth » Sat Jan 06, 2018 11:41 am
Could you give us the data?
nicotrader
Postby nicotrader » Mon Jan 08, 2018 12:27 am
data.xlsx
data
(232.2 KiB) Downloaded 300 times
Postby EViews Gareth » Mon Jan 08, 2018 9:26 am
If I run the following:
wfopen data.xlsx
smpl 1 10361
equation eq1.switchreg(type=markov, nstates=3) series01 c
smpl @all
eq1.fit yf1
eq1.fit yf2
show yf1 yf2
I obtain identical results.
nicotrader
Postby nicotrader » Mon Jan 08, 2018 3:06 pm
Sure????
This is the forecast output with in sample 10361 and out of sample 12536.
https://ibb.co/nezghR
totally different to in sample 10361 out of sample 12200.....
Postby EViews Gareth » Mon Jan 08, 2018 3:25 pm
Did you run the code I provided and achieve the same results or different ones?
Users browsing this forum: Google [Bot] and 29 guests
