BBQ add-in
dakila
BBQ add-in
Postby dakila » Fri Dec 15, 2017 2:19 pm
This thread is about the BBQ add-in that implements the Bry-Boschan (NBER) Business Cycle Dating Algorithm modified by Harding and Pagan for quarterly data
terrya
Re: BBQ add-in
Postby terrya » Sat Dec 16, 2017 3:29 pm
It appears that this isn't linking properly (as the BN filter did initially).
dakila
Re: BBQ add-in
Postby dakila » Sat Dec 16, 2017 4:33 pm
Yes, that link is not working. Gareth, please fix it.
Re: BBQ add-in
Postby EViews Gareth » Sat Dec 16, 2017 5:20 pm
Works for me - try refreshing.
dakila
Re: BBQ add-in
Postby dakila » Sat Dec 16, 2017 6:13 pm
Thanks it's working now.
terrya
Re: BBQ add-in
Postby terrya » Mon Dec 18, 2017 10:04 pm
With the following file when I run the add-in, the series GDPESA crashes resulting in the syntax error message. What's going wrong? The other 2 series give the right dating. (As an aside, the R package can evaluate GDPESA without problems.)
RGDPSANSA.xls
(34.5 KiB) Downloaded 112 times
terrya
Re: BBQ add-in
Postby terrya » Tue Dec 19, 2017 3:38 pm
Further to this. Another data series, starting 1955Q1, wouldn't evaluate and the error message was "rows undefined". There's no problem with the data file when I use either R or Winrats 9.2. The recession periods generated in R and Winrats agree closely and are plausible, given the known events.
dakila
Re: BBQ add-in
Postby dakila » Tue Dec 19, 2017 4:05 pm
I fixed the bugs. Please update it.
terrya
Re: BBQ add-in
Postby terrya » Tue Dec 19, 2017 4:08 pm
Thanks will try late
terrya
Re: BBQ add-in
Postby terrya » Tue Dec 19, 2017 4:12 pm
Installed add-in as suggested. Definitely working. Thanks.
joff
Re: BBQ add-in
Postby joff » Fri Jan 05, 2018 5:16 am
Hi. I have tested the add-in using US GDP data from 1947q1 to 2017q3 over the whole sample the add-in works fine. However, when I play with the sample lenght I get two error messages (replication files are attached):
- Non numeric argument (e.g. for sample 1985q1 2017q3)
- Division by zero (e.g. for sample 1990q1 2017q3)
Since the program is encrypted could you please check for me what is causing these errors? I don't see the theoretical reason why the BB algorithm would not work in these cases.
Thank you in advance.
bb_us_test.wf1
(13.1 KiB) Downloaded 95 times
bb_us_test.prg
(336 Bytes) Downloaded 81 times
dakila
Re: BBQ add-in
Postby dakila » Tue Jan 09, 2018 6:12 pm
Hi, I fixed the bugs. Please update it.
dakila
Re: BBQ add-in
Postby dakila » Tue Jan 16, 2018 3:36 pm
Hi there,
Please update the add-in. Now it can handle series with NA correctly.
Return to “Add-in Support”
