is the three-stage estimation method of the DCC-GARCH available, the addin has only the 2 step estimation method,
Help is much appreciated,
Dynamic conditional correlation multivariate GARCH
Re: Dynamic conditional correlation multivariate GARCH
Hvtcapollo wrote:You can consider this code. I used it last year for my research and you should be ok if using it for the bivariate. For trivariate u need to modify a litle bit especially for the log likelihood function.Code: Select all
'change path to program path
%path=@runpath
cd %path
'load workfile containing the return series
load nikkei_sp.WF1
'set sample range
sample s1 1/06/1995 12/25/2007
scalar pi=3.14159
'defining the return series in terms of y1 and y2
series y1=r_nikkei
series y2=r_sp
'fitting univariate GARCH(1,1) models to each of the two returns series
equation eq_y1.arch(1,1,m=1000,h) y1 c
equation eq_y2.arch(1,1,m=1000,h) y2 c
'extract the standardized residual series from the GARCH fit
eq_y1.makeresids(s) z1
eq_y2.makeresids(s) z2
'extract garch series from univariate fit
eq_y1.makegarch() garch1
eq_y2.makegarch() garch2
'Caculate sample variance of series z1, z2 and covariance of z1and z2 and correlation between z1 and z2
scalar var_z1=@var(z1)
scalar var_z2=@var(z2)
scalar cov_z1z2=@cov(z1,z2)
scalar corr12=@cor(z1,z2)
'defining the starting values for the var(z1) var(z2) and covariance (z1,z2)
series var_z1t=var_z1
series var_z2t=var_z2
series cov_z1tz2t=cov_z1z2
'declare the coefficient starting values
coef(2) T
T(1)=0.2
T(2)=0.7
' LOG LIKELIHOOD for correlation part
' set up the likelihood
' 1) open a new blank likelihood object and name it 'dcc'
' 2) specify the log likelihood model by append
logl dcc
dcc.append @logl logl
'specify var_z1t, var_z2t, cov_z1tz2t
dcc.append var_z1t=@nan(1-T(1)-T(2)+T(1)*(z1(-1)^2)+T(2)*var_z1t(-1),1)
dcc.append var_z2t=@nan(1-T(1)-T(2)+T(1)*(z2(-1)^2)+T(2)*var_z2t(-1),1)
dcc.append cov_z1tz2t=@nan((1-T(1)-T(2))*corr12+T(1)*z1(-1)*z2(-1)+T(2)*cov_z1tz2t(-1),1)
dcc.append pen=(var_z1t<0)+(var_z2t<0)
'specify rho12
dcc.append rho12=cov_z1tz2t/@sqrt(@abs(var_z1t*var_z2t))
'defining the determinant of correlation matrix and determinant of Dt
dcc.append detrRt=(1-(rho12^2))
dcc.append detrDt=@sqrt(garch1*garch2)
dcc.append pen=pen+(detrRt<0)
dcc.append detrRt=@abs(detrRt)
'define the log likelihood function
dcc.append logl=(-1/2)*(2*log(2*pi)+log(detrRt)+(z1^2+z2^2-2*rho12*z1*z2)/detrRt)-10*pen
'estimate the model
smpl s1
dcc.ml(showopts, m=500, c=1e-5)
'display output and graphs
show dcc.output
graph corr.line rho12
show corr
vivian wrote:Thanks very much for sharing the code. I used this code for my research as well, it turned out that there is always an error box saying " Missing values in @LOGL series at current coefficients at observation 1 in 'DO_DCC.ML(SHOWOPTS, M=500,C=1E-5)' "
Could you guys tell me where went wrong? I will really appreciate your help ....
so sad ....
Change your starting sample date from 3rd observation @last
I want to say in program start your sample from 3rd observation to last
It worked for me
Yes it is working starting with 3rd observation. Thank you Sunita mam.
Regards
Khyati Kathuria
Regards
Khyati Kathuria
But mam when I am using the codes of ADCC Model by Cappiello et al (2006), they are giving an error message,"Missing values in @LOGL series at current coefficients at observation 2/01/2003 in "DO_ DCC.ML(B, SHOWOPTS,
M=1000, C=1E-5", How do I resolve it?
Best
Khyati
Best
Khyati
Hi. I am using this code by Hvtcapollo for a DCC-GARCH model. I am thereafter trying to use a term from the model (the pairwise dcc) to regress an equation such as p(ij,t) = y0 +y1Dcovid where Dcovid is a dummy. What I am not sure about is how to get this term(pairwise dcc, or p in this equation) or which step it is in the code:
[co'change path to program path
%path=@runpath
cd %path
load nikkei_sp.WF1
'set sample range
sample s1 1/04/2017 01/04/2020
scalar pi=3.14159
series y1=ret_btc
series y2=r_jse
coef(2) T
T(1)=0.2
T(2)=0.7
logl dcc
'specify rho12
'estimate the model
smpl s1
show dcc.output
show corrde][/code]
%path=@runpath
cd %path
load nikkei_sp.WF1
'set sample range
scalar pi=3.14159
series y1=ret_btc
series y2=r_jse
coef(2) T
T(1)=0.2
T(2)=0.7
logl dcc
'specify rho12
'estimate the model
smpl s1
show dcc.output
show corrde][/code]
Hi!
How to generate DCC-based conditional covariances in Eviews? I have to generate the DCC-based covariance matrix between the individual stock and the market portfolio. Are we supposed to use the drop-down or codes? Kindly help me out with it.
Thank you.
Thank you.
Users browsing this forum: No registered users and 21 guests
