Forecasting using Logl object
obaid610
Postby obaid610 » Tue Nov 14, 2017 12:10 am
Hi Everyone
I have questions regarding forecasting the dependent variable using logl object. Lets supposed we have the following model:
series res = y - c(1) - c(2)*x - c(3)*z
series var = c(4) * z^c(5)
series logl1 = log(@dnorm(res/@sqrt(var))) - log(var)/2
How can I forecast the values of "y" in the above equation? I have looked into the makemodel option but in the generated equation, "res" is the dependent variable. Is there option to edit the generated equation to the following specification y = c(1) + c(2)*x + res?
Any help would be greatly appreciated.
Thanks in advance
Re: Forecasting using Logl object
Postby EViews Gareth » Tue Nov 14, 2017 9:26 am
You could add a line to the model that creates a new variable that is res+c(1)+c(2)*x+c(3)*z
obaid610
Postby obaid610 » Tue Nov 14, 2017 7:32 pm
Wow, silly me. Thanks for the help
Cheers
Return to “Models”
