Run SQL Server parametrized stored procedure
vpilia
Postby vpilia » Mon Nov 13, 2017 9:19 am
I need to execute a parametrized stored procedure on MS SQL Server, that does not pull data.
It is a write-to-log in fact.
(stored procedure works fine when launched from SQL Management Studio)
Tried to open a dummy workfile but won't work
wfopen(wf=xxx,page=d,type=odbc,timeout=120) Description=DEV_STG;DRIVER=ODBC Driver 13 for SQL Server;SERVER=servername;Trusted_Connection=Yes;APP=EViews;DATABASE=STG;  "{call [STG].[Eviews].[log_Eviews_staging] ('"{%param1}"', '"{%param2}"')}" @keep *
wfclose xxx
Error message:
ODBC Error unable to connect to driver: in "WFOPEN
(WF=XXX,PAGE=D,TYPE=ODBC,TIMEOUT=120)
DESCRIPTION=DEV_STG;DRIVER=ODBC DRIVER 13 FOR SQL
SERVER;SERVER=CHTSGVA-DB83,1435;TRUSTED_CONNECTI
ON=YES;APP=EVIEWS;DATABASE=STG; "{CALL
[STG].[EVIEWS].[LOG_EVIEWS_STAGING] ('"CHL"',
'"CHILE"')}" @KEEP *".
Bizarrely, the same driver works few lines before on the wfsave command
Any ideas?
Re: Run SQL Server parametrized stored procedure
Postby EViews Steve » Tue Nov 14, 2017 8:29 am
Try using quotes around your connection string, like this:
wfopen(wf=xxx,page=d,type=odbc,timeout=120) "Description=DEV_STG;DRIVER=ODBC Driver 13 for SQL Server;SERVER=servername;Trusted_Connection=Yes;APP=EViews;DATABASE=STG;"  "{call [STG].[Eviews].[log_Eviews_staging] ('"{%param1}"', '"{%param2}"')}" @keep *
But honestly, calling a stored procedure this way via WFOPEN is probably not the best way to do it as WFOPEN will try and expect something to be returned by the call. Why don't you create a separate program that calls your stored procedure (such as via VBS script or a simple .NET console program), then call the program from EViews using SHELL or SPAWN?
Users browsing this forum: No registered users and 10 guests
